Question about Grohe Plumbing
I have a Grohe stopper in my bathroom sink, how do I take it out to replace it?
  • 19 Answers
SOURCE: CHIPPED PAINT ON BATHROOM SINK DRAIN STOPPER
you need to remove the brass ring from the tub and buy acan of spray paint for metal you will be able to find it in a brass finish
Posted on Feb 02, 2009
  • 63 Answers
SOURCE: Bathroom sink stopper came unhooked and out, not attached anymore
You will need to get under there and unscrew the popup rod located on the back of the drain. pull out the rod, drop the stopper in there and push the rod through the hole in the bottom of the stopper. screw the nut back on.
Posted on Mar 16, 2009
  • 30 Answers
SOURCE: Our bathroom pedestal sink is very slow drain and
You shouldn't have to disassemble everything in order to get to the trap (elbow joint). Most pedestal sinks are designed so that you can get to the trap from the back (generally after getting down on your hands and knees and crawling around with a flashlight). Most sink stoppers that are worked from the faucet itself have a little bar that extends down the back of the sink behind the drain. It will clip with a little metal piece to a lever that sticks out the back of the drain before the trap. The lever goes through a hole in the drain and pokes into a hole in the bottom of your sink stopper. As you move the lever, you will notice that your stopper goes up and down.
Unclip the rod from the lever and you should be able to unscrew the lever from the back of the drain (don't loose the little gasket that sits inside the screw-cap as it keeps water from leaking out here). At this point, you can pull out the stopper and see what is going on. If cleaning off the stuff attached to your stopper doesn't solve the problem, you can then remove the trap to see if anything is clogging that. Hopefully, by this point, your sink clog has been identified and you just need to reassemble, making sure when you put your stopper lever back in that you actually get it into the appropriate hole in the stopper itself.
If this doesn't solve your problem, it's more serious and you probably want to call a plumber as the issue is either a clog farther along or a problem with the venting of the sink drain.
Posted on Sep 18, 2009
  • 3 Answers
SOURCE: I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Posted on Jan 03, 2010
  • 128 Answers
SOURCE: stopper came out Pegasus bathroom sink
Pegasus make several models but I'll make an assumption that it has a pop-up plug actuated by a rod just behind the tap head.
If correct....
Under the sink in the cabinet you will see the rod comes down and connects to an adjustment fitting and into the main drain line from the sink. There will be a fitting on the drain line holding the connection. Inside is a metal ball and connecting rod that links to your plug.
Remove the fitting.
Slide the ball and rod partially out.
Put your plug back in.
Engage the rod again (you will need to fiddle a bit here).
Tighten the fitting.
Run water to ensure the fitting is tight and not leaking.
Should be good to go.
Please rate this answer if it gives you some direction.
Posted on Mar 13, 2010
The sink stopper came off on my talia bathroom faucet and I can't get it back on
UNDER THE SINK ABOVE THE TRAP IS A TAILPICE WITH A ROD POINTING TOWARD THE BACK WALL. IT IS HELD IN PLACE WITH A NUT. REMOVE THE NUT. PULL THE ROD OUT. TURN THE POPUP LOOP TOWARDS THE BACK WALL SO YOU CAN PUT THE ROD THROUGH IT.SNUG THE NUT UP AND CK TO BE SURE IT WORKS. FILL SINK WITH WATER AND CK FOR LEAKS.
Apr 18, 2014 | Grohe Talia Widespread Bathroom Faucet...
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
My Grohe soap dispenser leaks under the sink. The bottle simply hangs off the pump. It looks like it should screw on the dispenser but there was no nut. Is this correct?
Virtually all soap/lotion bottles have threads on the top of the bottle and are designed for initial installation only since all if them are refillable by pulling up on the pump head. Grab the bottle and twist to the right. If it will not tighten then the threads are stripped out and complet dispenser replacement is required. Grohe does not sell either the pump assembly nor the bottle separately.
Sep 28, 2010 | Grohe Satin Nickel Soap Dispenser...
The bathroom drain stopper will not stay closed.
there is a small compression nut on the drain, it needs to be tightened slightly. look under the sink when you pull the lever up close the stopper, you will see where it connects to the drain. tighten that nut slightly.
do not over tighten or you won't be able to move the stopper at all, you just need enough pressure to hold the weight of the lifting rod and stopper in place.
May 12, 2010 | Home
Stopper has dislodged.
Hello. It is probably not broken. In order to fix it, you must go under the sink and above the trap. You will see where the lever for the stopper is attached and can be adjusted. If necessary look under another working sink with a similar set up. Joe
Apr 15, 2010 | Kohler Caxton Undercounter Lavatory Sink...
I AM LOOKING FOR A THE RING AROUNG THE DRAIN HOLE FOR A PEGASUS BIMINI VANITY
Standard rings can be bought at your local hardware store. It will be easiest to replace the whole stopper assembly instead of trying to match the ring to an existing stopper. You will need some plumbers putty and a pipe wrench.
Feb 11, 2010 | Pegasus Technologies Pegasus Pegasus...
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Where can I find a new sink stopper for a Toto pedestal bathroom sink?
go to your local whole saler , you won't find one at your local harware store.
Aug 29, 2009 | Toto LPT972.8-01 Guinevere Pedestal...
Mar 15, 2009 | Home
Plumbing Logo
201 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
