Question about Mr Steam Ms Super 1e Steam Shower Generator
Steam shower wont turn on getting a flashing temp on controller in shower
    Problem Solver:
  • 11 Answers
Hi I am with Mr. Steam Tech Support please call 800-767-8326 and ask for tech support. please have your serial number and we will be able at assit you in getting your unit up and running
Thanks
Mike
Mr. Steam
Product Support
Posted on Nov 16, 2010
Turn on steam in shower, but no steam comes out
So many things could be wrong. 1 check circuit breaker. 2. Check there is water going to steam unit. Power to control in shower? Steam unit could be burned out. Or control is not working or thermostat not working.
Apr 08, 2015 | Electrical Supplies
Shower problems I have a zy-137 shower and steam cubicle The steam wasn't commingled through the valve and I turned it to have a look one it has come unscrewed and there is a visible hole and I am unable...
Somehow you have to get that pipe coming back through the wall of the shower.
There is a pipe with threads on it that the nozzle threads onto.
Once you can get that pipe back through the shower wall you can thread the steam nozzle back on.
If the steam nozzle has been replaced onto the threaded pipe you can trouble shoot your steamer as to why there is no steam coming out.
ROD
U S Parts Center
May 14, 2014 | Home
SM-9-901 Generator Steam Shower
There are three things that affect this:
1. Incoming water temp.
2. Incoming water volume.
3.Temp of the device.
There are some other minute things like humitidty and altitude too.
Jul 21, 2013 | Steamist SM-9-901 Generator Steam Shower
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
Mr.Steamer Commercial Steambath CU750A temp is to high it is out of control
There are only 3 likely causes. The first and most likely is the room sensor inside the shower. This is a resistive type sensor that communicates the temperature in the room to the controller via ohm ratings. There is an equivalent ohm rating for every degree of temperature it correlates to and that is how the temperature controller knows what temp it is in the room. Often in commercial steam rooms clients tend to spray cold water on the sensor which causes damage and alters the ohm rating to the point where the sensor is relaying incorrect room temps to the controller, causing high or low temperatures. Normally when the room is hot, it causes the alloy metal of the sensor to be hot. When cold water is sprayed on it, it immediately bring down the temp of the alloy and the thermal shock warps the metal causing the resistance values to change. Set your multi-meter to ohms and remove the sensor wires from the back of the controller. You will do your ohm reading on the sensor wires. Check the actual room temperature with a thermometer. At room temp 77 degrees you should be getting 10,000 ohms, at 100 degrees you should get 5827 ohms, and at 120 degrees you should get 3759 ohms. Note as the temp goes up the ohms go down, this should help you determine if your sensor is good. The other possibility is your steam solenoid valve is stuck in the open position. Simply check if there is voltage running to the solenoid. If there is no voltage but the room is filling with steam your solenoid is stuck open and needs to be replaced. The last is the controller, and by process of elimination if the sensor and steam solenoid are good then the controller may be the issue.
Feb 02, 2012 | Mr Steam Mr. Steam Commercial Steambath...
Maax steam shower
To get replacement parts for Maax steam shower, you can prefer showerenclosures.
Nov 13, 2011 | Home
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Thermasol Pro 150 - 25094. Doesn't work. I have a very simple controller. Just a gib gray button and four other led lights near the 15 , 30, 45, and 60 lights to set the time. I think I need to do the auto...
yes thats correct or if you have manuel flush at the genrator there is a ball valve. open for minutes then close and run generator for thirty minutes without anyone in the shower.
Mar 12, 2009 | Thermasol Steam Bath Generators - Ambiance...
Mr Steam Ms Super 1e Steam Shower Generator Logo
790 people viewed this question
Top Mr Steam Electrical Supplies Experts
BJ Russell
Hippy_dd
Are you a Mr Steam Electrical Supply Expert? Answer questions, earn points and help others
