Question about Toshiba TW40F80 40" Rear Projection Television
I bought this Toshiba model # TW49f80 from an auction for about $40 ($150 for 4 sets ) all worked fine except this Toshiba ,when turned on only power light turns on (red) nothing else no audio or video only click ,I ts and stats red and sometimes blinking red, any idea what it could be should just junk it?
  • tony amri Nov 14, 2010
    I don't know what I did for it to blink first time (holding menu or another button and turn it on hoping to enter some reset mode or something ) but I can't get it to blink anymore ( don't know if it's good or bad news ) so when pushing "on" only Red light turns on and nothing else (I do hear a clik
  • Toshiba Master
  • 11,800 Answers
The blinking signals that the power source has been shut down by its own protection system because another component has failed. When this happens it's usually a very big defect, expensive to fix - the blinking is a code, telling you with approximation what part has failed.
Most likely the previous owners have encountered this fault, decided that it's not worth fixing it and kept the tv for parts (even if you will only need the screen and it's worth keeping it). You should do the same.
Posted on Nov 14, 2010
  • Azrael SRL Nov 14, 2010
    The error is displayed when you start the tv with the Menu button pressed for at least 2 seconds. If no error is displayed now it means that the fault has extended to the control processor - a very bad news. A steady red means that the power source is completely offline, the click is the power relay being disengaged. Definitely this tv is dead.
We purchased our son the Bachmann Big Hauler train set (used). All works fine, with the exception of the r/c transmitter. The very tip is broken off and therefore, does not allow the transmitter to w
best option is to look for one on one of the online auction sites.
be sure it transmits on the same frequency there should be tags on the locomotive & transmitter identifying the frequency.
Feb 10, 2014 | Bachmann Big Hauler Radio Controlled Train
My new toshiba 32 inch regza turns on but thats all it does? no picture, sound even menu dosnt come up
First if a "new" set and if in warranty--have them deal with the problem.
If nothing on remote except on and off works--it is a micro problem (microprocessor) in the set.
I assume you did unplug the set---wait and plug it back as that could allow the micro to reset.
The key clue here is nothing on remote works except on/off?
Mar 30, 2012 | Toshiba REGZA 47HL167 TV
My horn does not work. I press the horn, but all i hear is a click in the fuse box. Checked the fuse and it is good. I bought it from a auction and had problems with the alarm and locking because i didnt...
If the horn fuse ( Fuse #26 ) is installed and has power on both sides of the fuse, you might want to check that the horn connector is still on the horns.
The horn relay is not serviceable in the fuse panel.
You can test the horn connector for power, the Yellow w/ Light Green wire, when the horn button is pressed.
Feb 02, 2010 | 2005 Ford F-150
Toshiba 40XV645U - No picture on HDMI 1 when TV is turned on
I assume that you have set the input source selction as in Page 32 and HDMI 1 is solid and and not grayed out. If so check the Preferences menu and see if there is an option for power on set up.
Also look at page 51 about HDMI feature settings. I assume you turn the cable box on first before turning the TV on.
Dec 19, 2009 | Computers & Internet
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Have a P105 S6164 bought used lcd screen very dim
With the replacement screen did you replace the inverter board? Many laptop screens also have a very small fuse built into their power connecttions. Check this also.
Apr 03, 2009 | Toshiba Satellite P105-S6104 Notebook
I bought a toshiba e350 at an auction sale and control panel does not light up.
On the e350 there is a brightness control on the left side of the control panel. Is is up all the way?
Sep 03, 2008 | Toshiba e-Studio 350 Copier
Problem with Toshiba Laptop A215-S7437
If you go into control panel and check out your power options. Make sure that your system is set to never shut off the monitor. This will of course waste battery power (if you run off battery) so you will have to decide which is best for you.
If the power settings are not to blame then maybe you do have a hardware issue. Some laptops have a hotkey combination that if coincidentally you are typing and you press the right key combination you send it into hibernation. You can check this via the power settings.
Mar 20, 2008 | HP Pavilion dv6000z Notebook
On/off switch Toshiba model CX32D60
what i have done in the past is use one of the other buttons, if it's a push switch what ive done is hard soldered and then use a wall switch to turn it off.
Dec 10, 2007 | Toshiba 32AF43 32" TV
MY CAMERA ONLY DISPLAYS EVERYTHING IN GREE
almost sounds like it's in night shot mode, but I don't think to 2000 has that. sometimes during shipping the board to board connectors may have come loose. I would check for a loose one off the 3 ccd assembly. Thats a pretty good unit you have there, worth looking into. be carefull taking it apart there is a some 4 pin ribbon cable that can rip, just take it slow. I work on alot of these. they are a workhorse.
Sep 14, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
Televison & Video Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
