Sony Vaio VGN-NR180E
I have a Sony Vaio as described above, the computer is roughly 6 months old and according to CHKDSK the harddrive is ok, however the sony diagnostics are detecting damage on the harddrive. I have a 2 year extended warrenty as well as the sony warrenty, what will the warrenty from best buy do regarding this issue? I am nearly certain the harddisk is somehow damaged in a way CHKDSK is not looking for, being that it is a toshiba I cannot get any software from the manufactuer of that specific piece of hardware to inspect the drive prior to conceeding defeat and handing the problem to someone else to deal with. Right now I am working with a barely restored, partially functional computer that needs to be fixed.
  • md081283 Jun 19, 2008
    Yes I did chkdsk, Vista makes it a royal pain to do this, but I tried and made it scan, it claimed it was clean. I did the checkdisk through windows utilities as well as in the recovery tool (under command prompt) ":chkdsk c: /f". Since I have rebooted it and updated it SMART now detects the drive is dead, so I hope that the warrenties will cover it considering the length of time and the degredation of the drive I have a feeling it was a defect that has caused this fault. In the least now I know that whoever it is that tries to service it will get a nice notice now from SMART telling them the Harddrive is damaged and will likely loose data now so they should not have too much difficulty getting the idea that it is the harddrive that is broken. I still wonder why the SMART detection failled to recognize the fault untill it became totally destroyed, on previous computers that had the SMART Hardware technology it was usually good about detecting damage prior to it destroying the drive completely (allowing you to backup your data first).
    Guru:
  • 1,342 Answers
If you are pretty sure the hard drive is faulty I would use the warranties and have it replaced.
Did you try running chkdsk with the /r switch?
Go to Start, Run, type cmd and hit OK. When the dos screen opens type chkdsk /r (note the space between the k and the /). It will probably say it cannot do it until the next boot. Enter y for yes. When your PC restarts chkdsk should go through 5 stages and display a summary of what was found and what it did when it finishes.
Posted on Jun 18, 2008
BIOS PASSWORD SONY VGN-NR180E
Remove the main battery then remove backup battery(small flat cell) wait for an hour and re install both batteries then try starting it
Dec 27, 2014 | Sony VAIO VGN-NR180E/S Core 2 Duo T5250...
Failed Bios Flash on Sony Vaio Laptop VGN-NR180E : Won't Boot
Try removing the battery, unplug from power and push the power button to clear any static or errant voltage. If this does not work, try inserting the windows disk, or recovery disk and turn on computer. It may boot into the recovery mode. Let it do an automatic recovery. Thirdly, If you can download the bios from sony that belongs in that machine, you can flash the bios back to what version belongs there.
Dec 21, 2017 | Computers & Internet
How do i remove the harddrive from a sony vaio vgn-sz120p
Hi dekoreya.
You may remove the Hard Drive of the Notebook by referring to the Service Manual.
Link to download the Service Manual for the VGNSZ Series Notebooks:
http://tim.id.au/laptops/sony/vgn-sz.pdf
Please download the above Service Manual from the above link.
The Service Manual has the detailed information to remove the Hard Drive.
Hope this helps.
Please feel free to contact for further information and assistance.
Aug 03, 2010 | Sony VAIO VGN-SZ120P/B Notebook
How to change hard drive on Sony VGN-N130G?
I need the model number printed on the front of your case, VGN-N130G does not exsist on the sony web support page. http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB
Usually there is a cover under your laptop that is marked.
Remove 1 or 2 screws and your harddrive should just slide out.
Jul 14, 2010 | Sony VAIO VGN-N130G/W Notebook
My Sony Vaio PCG 3C2L will not turn on. It looks
it sounds like a problem with your harddrive. if you have an oem copy of your OS then you could do a chkdsk /r from this. If not then the harddrive will have to be removed and the chkdsk /r done from a data reader from another computer. Hope this helps, leave feedback
Jul 03, 2010 | Sony VAIO Notebook
My Sony VGN-NR180E will not shut down when shutting down.
Some fo the software crashes whie it's shutting down. Either load up a system restore point from before theis problem started, or reinstall some of the software until you no longer get the problem.
Careful with system restore because when you select a date for it to go back to it will uninstall any software that you installed after that date. It will NOT delete your personal data, like pictures, music, etc even if you put them on the computer after the date selected.
Nov 26, 2009 | Sony VAIO VGN-NR180EW Notebook
The mouse is frozen in my Sony Vaio VGN-NR180E . It won't move .It also looks like the screen is locked.It feels like my mouse is locked. Thanks so much for your help!
Restart the computer-
Plug up a USB mouse to see if that doesn't work
Your touch pad software may not be installed. Goto Sony's device driver support page and download the mouse drivers for your model. Sony has good software support. You'll find the touchpad program easy. Reload and see where that puts you.
Nov 11, 2009 | Sony VAIO VGN-NR180EW Notebook
I want to disable my touch pad on my vgn nr180e.
To disable the touchpad go to:
Start Menu
Control Panel(make sure it is in classic view)
Vaio Control Center
Expand the Mice and Pointing devices option. You should see the option to disable the pointing device as a tick box, just untick it
Regards,
Purito
Oct 17, 2009 | Sony VAIO VGN-C250N/B PC Notebook
Computers & Internet Logo
571 people viewed this question
David Payne
David Payne
