No picture, have sound, dvd player works (w/o pic), cables intact, etc........
    Genius:
  • 1,550 Answers
Don't you activate the progresive scan for mistake,if you do it need to deactivate him.Good luck
Posted on Jun 19, 2008
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
The DVD player is running a movie with no picture or sound, the TV screen is showing an icon that says no signal...How do I get the movie to run with sound?
try using a different input on your tv. If possible try using a different cord to hook the dvd player to the TV. If neither solution works it sounds like a faulty dvd player.
also try using a different source on the tv like another dvd player, cable etc. etc. hopefully on the same input to make sure the tv is working properly .
Mar 03, 2011 | Dynex Televison & Video
Original installation color flared up around edges and outlines
what she tried to sell her was and HDMI cable for hi def signal between box and tv. now with what your describing sounds like panel solarization. if you can send me a pic i could better verify your problem. sent pic to support@cats-inc.us
Apr 27, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
My tv got no sound..but if connect a video/dvd via rca ok.
Sounds like you have a tuner or an antenna problem. If you are using a DVT converter box to watch off the air TV, the signal has to be very good to get sound and picture. Try connecting a VCR or a DVD player trough the coax cable and see if it you get sound an pic on Channel 3 or 4. If you do, it is an antenna problem.
Nov 30, 2009 | Televison & Video
My Samsung HC-p4363w have no pic or sound but the power red light is on
Try pushing the "source" button on remote or on the TV. Wait about 5 seconds, if no picture, push again. Do this at least 6 times or until you get a picture. With each push, the TV will look for cable input, dvd input, etc. until it finds your cable signal.
Also make sure your cable/antenna is hooked up and working.
If that doesn't work, hold down the "enter" button for 10 seconds to reset the tv to original factory settings. Then follow the on-screen menu setup instructions.
-please rate me. Thanks and good luck.
Nov 20, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Main screen has no picture
go to you`r pics and change wich pic you want.
Jun 27, 2009 | Durabrand DUR7 Portable DVD Player
Samsung dvd player S224 pictures on screen are in red tones only
how is video on the dvd player hooked up? via s-video, component cables ( r,g,b), or the yellow cable? if it is the yellow cable then i beleive to be something wrong with the unit but just make sure you are plugging into the yellow input on tv. if it is the other types make sure you dont have the rgb cables mixed up. it is very easy to mix up the 3 wires. if it is the s-video cable try a different one if you can and make sure all pins are intact when you remove them. i hope this helps and good luck
Feb 19, 2009 | Televison & Video
When running video thru the amp, the pic flashes on and off
usually that is an issue of cabling and/or the monitor. The Marantz units are pretty darn stable. Check your setup to see if it is upconverting.
If you can, try a new HDMI cable to the TV. You could also try the second HDMI out, to see if there might be a problem with that particular output port. You can also try a different HDMI port on the TV.
Another thing to try is to directly connect your DVD player to the TV. If your cabling is all in walls, etc, you can get an HDMI coupler at a big box store for $15.00 or so. That will tell you if it is any of the cables, the DVD player, or the TV.
Jan 05, 2009 | Marantz SR7002 6.1 Channels Receiver
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
