Question about JBL CREATURE II Computer Speakers
Fixing power supply
Ok. I read your post about how to fix the creature jbl power supply where you say we have to open it to get the fuse and replace it. Well, I would like to know how can I open the box since it is locked. Do I have to use a knife or some knife or a hot iron? How do I do it?
  • jeffrandspe Jul 10, 2008
    The power supply that I have doesn't work either, but I think the fuse was changed already and may have been replaced with the wrong fuse. What fuse should be used in the power supply?
  • basaUK Aug 26, 2008
    I have a similar problem.
    Facts: The fuse is located within the power supply and is a 5amp quickblow type. The power supply casing needs to be prised apart with a flat bladed screwdriver or similar. Takes a bit of doing - might even need a bit of of a hammer.
    However, as the fuse has now blown three times as soon as I replaced it I deduced that it must be something else. I've opened up the woofer itself and can't see anything suspicious.
    So, I'm also stuck. Anyone else?
    Basa
Hello, sorry for late reply. See last post:
"The power supply casing needs to be prised apart with a flat bladed screwdriver or similar. Takes a bit of doing - might even need a bit of of a hammer."
You have to slightly damage the casing to prise the two halves apart and it won't go back together properly - needs must!
In any case, replacing the fuse doesn't solve the problem as they keep blowing. There is a fault somewhere causing this to happen and that's where I'm stuck.
Anyone else??
Posted on Nov 05, 2008
How many input voltage do i need for my jbl creature ii.is it ac or dc?
JBL Creature needs a 18V, 3.5 Amp, AC power supply. JBL original power supply model is TA66180350-B2 made in China. In put power is 220-240V, 50 Hz-0.5 Amps. The AC supply is made to a dual rail supply inside the creature using a diode bridge.
Sep 08, 2014 | JBL CREATURE II Computer Speakers
JBL CREATURE II soundspeakers are dead without power
When the power to the system was applied to the speakers before you realized the cables were chewed, you blew some components in the power boards to the speakers. You could look to see if there are replaceable fuses. Otherwise a trip to the repair shop or new speakers.
Apr 08, 2014 | JBL Audio Players & Recorders
The tweeters on my JBL Creature speakers has been damaged ,,do you think it can be fix?
Send them back to manufacturer to fix they will more then likely have to replace the tweeters
Nov 26, 2010 | JBL CREATURE II Computer Speakers
No power to computer speakers
if the cable is fixed correctly then it would seem when your dog chewed through the cable the cables met and caused a power short out that has blown some of the internal electronics components there fore the unit will not work. taking into consideration the price of jbl creature speakers it would be cheaper to replace the unit than to have repaired ..
i hope this helped
Jul 03, 2010 | JBL CREATURE II Computer Speakers
Creature JBL
check for the switches is in on,then check the wires are connected properly
May 11, 2008 | HP JBL Platinum Computer Speakers
Jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Dec 17, 2007 | JBL CREATURE II Computer Speakers
Power supply
there is an internal fuse in the power supply adapter but you have to cut the box open to get to it.did this myself replaced the fuse and it now works fine
Dec 06, 2007 | JBL CREATURE II Computer Speakers
JBL Creature 2 Blowing Fuse
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
JBL CREATURE II Computer Speakers Logo
676 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
