Question about Eddie Bauer Lightweight Travel System 01-750-AFD
The wheel to our travel system was shut in a door and crushed, where can we find a replacement wheel
    Guru:
  • 541 Answers
Finding wheels for strollers is always a problem unless they sell them as spare parts like Bugaboo does. Check with a Eddie Bauer Store if they're unhelpful a plastic wheel can be repaired provided the tyre is still good. Google plastic welders (yes plastic can be welded) find one local and show them the wheel.
Posted on Nov 15, 2010
Garage door automatically reverses if you cross the safety beam when door is in upward travel
something is wrong supposed to reverse on downward movement only as not to crush you.. in upward not supposed to do that.. call chamberlain 800 number
Jan 25, 2015 | Chamberlain 1/2-HP Whisper Drive Belt...
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Candy crush keeps on crushing even before I start playing
delete app and re install. You will start where you left off. This helped me. .
Feb 13, 2014 | Wheeled Battery Charger - 6/12/24V, 12...
Resetting motor of a dominator garage door
Doe the motor have a battery back-up, or mains only?
Step 1: Disconnect the linking arm from the motor traveller, and test (by pressing button on remote or wall console), that motor runs traveller to the fully open position, and stops where the "open" limit switch is. Then run motor (by pressing button on remote or wall console), to the fully closed position. If the motor fails to run through a full open/ full close cycle, the limit switches require checking.Assuming that the motor runs through the full open/full closed cycle, focus on the door. All motors have built in circuitry, preventing motors from crushing objects. A double garage door should be able to be lifted easily by one hand. The door should be able to be left at any height, and remain there, or creep ever so slowly downwards (travel time of approx 10mm per 5 seconds is ok). If your door is properly balanced, and the motor will still not lift it, the control card on the motor is damaged, and requires replacement.
Jul 02, 2017 | Home Security
Door won't close
Check to see if anything is restricting it from closing inside of the crevice where the wheel travels and locks. Sometimes debris from trees, dirt or rocks can clog it up.
Feb 22, 2012 | 2003 Mazda MPV
I have replaced new gears and put back chain will only travel down 1 foot and back 1 foot light keeps flashing. Trying to get a full cycle?
When it only travels a short distance, and back up and the light flashes, that means that it's encountered too much resistance and the safety mechanism puts it in reverse and makes it go back up. This prevents children or pets from being crushed. Make sure that the gears are aligned and the chain is not getting hung up. There has to be some resistance causing the safety mechanism to go off. Also, if there is a safety Infra Red sensor hooked up to the system, make sure that it's wired correctly and free of obstruction. This can cause similar problems.
Mar 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Helo I have a KitchenAid KSBS25FKWHOO which is like this one. My problem is there is a push button for ice cubes or crushed ice and as of now no matter which button i push it gives crushed ice. How can I...
It sounds like your crushed ice flapper might be stuck.
Open the freezer and remove the ice bin by pulling toward you. Dump the ice into a container if you wish to save it.
Turn the bin upside down and look at the opening in the front that the ice drops out. There is a white flapper door that is controlled by a metal rod going all the way to the back of the ice bin. If you move the metal arm up and down from the back you should see the flapper door open and close. Open is for cubed ice and closed causes the cubes to travel through the blades and be crushed.
The most common failure is ice or frost build up around the flapper door that causes it to stick shut and not move to the open or cubed position. You can unthaw by running warm water through it in the sink. Dry completely before returning it to the freezer. Clean out any ice chunks from the chute in the door that might be slowing down ice. That should fix the problem.
Apr 18, 2010 | KitchenAid KSBS25IN Side by Side...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Apr 22, 2008 | Refrigerators
Ice dispenser in door clogged up or frozen
I see this a lot with people who mainly used crushed ice.  It will leave small pieces of ice behind and add up to a clogged situation.  If you mainly used crushed ice you will need to run full cubes thru every so often to keep the chute clear.  Another cause of this would be the flapper door on the dispenser doesn't close completely and warm air gets in and melts the ice in the bin so it clumps together and won't dispense.  In this case you may need to replace the solenoid that shuts the door and/or the door.  Let me know what you find.
Oct 15, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Eddie Bauer Lightweight Travel System 01-750-AFD Logo
133 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
