Question about Samsung P520
Samsung Armani When i try to activate the bluetooth is scans through and then displays the message connection failed.
  • 4 Answers
All you have to do is say "every day im hustlin!" out loud, and everything will be fine with your phone
Posted on Nov 11, 2008
How to pair the bluetooth of samsung SGH-T429
Hy gcahig, follow the instruction (note :if my solution was helpful please rate the answer) :STEP 1. Locate the Bluetooth Settings Menu
To pair the handset with a Bluetooth Device follow the steps below:
  1. From the standby screen, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Bluetooth (6)
STEP 2. Activate Bluetooth and Search for Device
  1. Select My Devices (2)
  2. Search for the Bluetooth device by pressing the left soft key for Select
  3. Press the left soft key for Yes to Activate Bluetooth and start the search
STEP 3. Pair with Selected Device
  1. Highlight the desired Bluetooth Device, using the navigation keys, then press the left soft key for Select
  2. Enter the Passkey "0000" then press the left soft key for Select
  3. The handset will display a brief message stating connecting followed by connected
  4. After being successfully connected you will return to the "My Devices" screen.
Source :
http://www.samsung.com/us/support/supportOwnersHowToGuidePopupPrint.do?howto_guide_seq=2765&howto_guide_step_no=1&prd_ia_cd=N0000003&map_seq=19095
Jul 13, 2012 | Samsung Cell Phones
Kindly help me connect my samsung HM1100 bluetooth headset to my playstation 3
1) Go to "Settings" on your PS3.
2) Scroll down and select "Accessory Settings."
3) Select "Manage Bluetooth Devices."
4) Select "Yes" when the message "The Bluetooth device has not been registered. Do you want to register?" is displayed.
5)
Turn on your Bluetooth headset when asked by the message "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, check the instructions supplied with the Bluetooth device." While each Bluetooth headset is different, for most this means to hold down the power button until the blue light on the device remains solidly lit.
6)
Select "Start Scanning" once your Bluetooth headset is in "pair" mode. Wait for the PS3 to scan for your Bluetooth headset. If the scan was successful, your Bluetooth headset will be listed on-screen. Select your headset from the list
7) Refer to the Bluetooth headset's instruction manual to find the pass key for your device (Usually the pass key is something simple like "0000" or "1234". Press "X" to bring up the on-screen keyboard and enter the pass key. Select "Enter" then "OK." "Register Completed" will display to confirm a successful connection.
NOTE: If the headset does not display after a scan, it may not be compatible with the PS3, or it is not properly set to "pair" mode. Refer to your Bluetooth headset instruction manual for directions to properly set your device to "pair mode."
If you want to check the User Manual for your Bluetooth, simply click on the following link:
http://www.samsung.com/us/support/downloads/BHM1100NBACSTA Click on the Icon below "File" Thank you.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Samsung P310 Bluetooth Activation Problem
I too had the same prob!
Here's what u have to do (the method that worked for me!) :-
*Go to Settings>Bluetooth>
*It displays options like 1. Activation, 2. My Devices etc.
Select "My Devices"
*Then select "Search for new devices"
That way it automatically turns the bluetooth on and searches for devices!! (quite odd if u ask me!)
After u have transferred ur stuff, u can deactivate it by using the "Off" option from Activation
Hope this helps u! :)
Feb 20, 2008 | Samsung SGH-P310 Cellular Phone
Samsung P520 Logo
67 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
