Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a 1/2 HP craftsman garage door opened with the key pad. The code started not working. WHen I try to reset, the keypad just flashes. HELP!
    President:
  • 3,197 Answers
Make sure the battery in the keypad is good. If you cannot get the keypad to work using this method to program then your keypad has failed.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Posted on Nov 15, 2010
5 Suggested Answers
SOURCE: garage door opener key pad not working
so i spent the better part of this morning trying to figure this same thing out... here's what I found.
You need to identify the serial number, which is found on the unit hanging from the ceiling... it will be like a 13953970. I found mine behind the lamp light protector thing. NOT the back with the stickers. 41A5021 is actually not the number that is important.
then go to www.managemyhome.com its a website ran by sears. you have to register, for free. then go look for manuals, in one of the tabs running across the top of the site is a choice for manuals. then search by Craftsman then enter the serial number.
then pull up the owners manual and check out the instructions.
** i found out that the old house i bought did not actually have the same keypad opener as came with the craftsman. so i had to closely inspect all sides of the internal keypad opener (not the one outside) and find another serial number. then i went and got the manual from www.managemyhome.com and realized i needed to add a new 9-V battery before I could proceed. So now i'm heading out to walmart to get that.
after a frusterating morning of service number and internet searches I hope after I get this damned battery the clouds will part and god will shine some luck on me.
goodluck to yourself!
Posted on Sep 29, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: craftsman outside keypad
On the back panel of the opener itself is a small pushbutton. Press the button and the indicator near it will light. While the indicator is lit, enter the new 4-digit code on your keypad and it will be set. (You are actually programming the receiver with the new code this way. The wireless keypad doesn't store a code.) The programming light goes off on its own.
Posted on Feb 13, 2009
glenmann62
  • 91 Answers
SOURCE: How do I code the garage door wireless key pad?
simple ;find the smart button on the opener and pressit ,their will be an indicater light next to the smart button that will remain lit ,then go over to the keypad and put your 4 digit code in example1234 then press enter on keypad and hold down for 3 seconds until garage door opener lightbulbs shut down and come back on , and thats it simple as pie! when the lights go on and off on your machine it,s telling you that it has received the code that you just programmed into it , guaranteed to work everytime , Thank you for letting me help you Sincerely Glenn mayer
Posted on Mar 05, 2009
swolfinor
  • 504 Answers
SOURCE: Garage Door Key Pad
Have you tried a new battery??
Posted on May 29, 2010
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp yellow button old garage dorr opener key pad will not open door tried a new battery and tried to re program it will nit work
It sounds like your keypad has just failed. Try programming it like this if you haven't.
Nov 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
I can't get my key pad for my garage door to open. can i reset my key pad to open my garage door???
You can reset the code but it sounds like it may have just failed. Make sure the battery is good and try more than one just in case. To reset the code:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Mar 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can't get it to open from the pad. I went to put in the code and it started flashing so I pressed the star button. after that, the code wouldn't work.
Try programming it again and see if that helps. Press and immediately release the smart/learn button and then walk over to your keypad and key in your 4 digit code and press enter.
Dec 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Mar 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door close with wireless remote entry but will not open
It sounds like this remote has lost its program! you will have to reprogram it!I hope this helps ya!
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door key pad
For most openers you don't need the old code.
Just press the program button on the powerhead enter the code you want in the keypad and press enter (within 20 seconds).
Jul 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door keypad
The blinking on your keypad simply means that a code of some sort was sent. Whether it be the right on or not. Lets try to reprogram the unit. Press the colored learn button on the motor head and then within 30 seconds enter in the 4 digit code followed by the up/down action button. The light bulb should flash to let you know it has been accepted. Wait 5 minutes and try. If it does not work replace the keypad.
Jul 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
109 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
