Question about NAD C545BEE
My NAD C545bee player`s buttons do not respond,even the power button.If the player is unplugged for a few minutes,all is well for the duration of a couple of cds,then the problem returns.However,there are no problems using the remote.
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: Hi Skipping problem with a NAD
hi
There is a diode in the power supply which gives dc supply to the laser focusing coil driver ic . if the diode get faulty this problem can occur. Just replace all the rectifier diodes in the power supply stage. Its better than searching for the exact one. then check the cd player is it skips the tracks. if then also its skips the tracks then you have to change the laser pickup unit.
ok
Posted on May 19, 2011
How to connect ONYZ home kit sirius to a NAD T775?
Try a factory reset of the receiver.
To perform a factory reset, press and hold the MENU and SOURCE buttons until Factory Reset is displayed. Then Power Off from Back panel for 1 minute and power up normally.
You may have damaged the receiver if you did not power off before installing the Onyx module.
Jul 27, 2014 | NAD Audio Players & Recorders
How to fix skipping problems for nad 545BEE
clean your player. your disk may be scratched if so you can't stop skipping
Sep 23, 2013 | NAD C545BEE
Hi Skipping problem with a NAD C545BEE, plays OK for 1 minute, then skips randomly wthin the track, then will skip to different tracks on the CD, like fast forwarding. No problems with the disc themselves
hi
ok
May 19, 2011 | NAD C545BEE
Screen does not light up
Hi
disconnect the power cable and remove the battery nad then press nad hold the power button for a minute. then connect every thing back and then see if the screen comes on.
in case it does not then again remove the battery nad power cable and remove the hard drive nad ram and put it back in again.
nad then check still does not work see if the screen comes on an external moniter, still if it does not come on call HP if it is under warrnty they would give you free repair.
Apr 12, 2010 | HP Pavilion dv2000t Notebook
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Power button flashes SAFE
I unplugged the unit for 30 minutes and it finally went out of safe mode.
Oct 12, 2008 | Televison & Video
Sharp a/c-#AF-S85FX
The e1 code is operated by a timer which stops the machine every 720 hours of run time. There are 2 procedures to reset this.
1) unplug the machine. Hold down the power button while plugging it back in and waiting for a beep of about 5 seconds duration. Release the power button. Unplug the machine again. Resume trying to use it as an air conditioner.
2) unplug the machine. Hold down the Mode button while plugging it back in and waiting for a 3 second beep. Release the mode button. The machine will start. turn it off by pressing the power button. Resume trying to use the air conditioner.
If these do not work, the "clean filter timer" is broken and will require you to replace some parts.
(Aren't you glad there is a computer is almost everything?)
Jul 24, 2008 | Heating & Cooling
Sanyo DVD player DWM-400 won't do work
I have a similar problem with the Sanyo DWM-400. I also cannot turn power off. Even when I unplug it and then again plug in the power cord it will come back on after several minutes all by its self. It will then work okay for a few minutes and will play a DVD and will suddenly quit showing a picture. It seems that something is overheating shortly after turning it on. After letting it sit and cool down for a while it will play again but only for few minutes. Although I have had this player since April 2004 it has rarely been used. I estimate it only been used no more than 10 hours total. With so many buyers having this problem Sanyo should issue a recall on this model.
Nov 26, 2007 | Sanyo DWM400 DVD Player
NAD C545BEE Logo
100 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
