Question about Breadman TR444 Bread Maker
My paddle keeps coming off when the dough is mixing. What's up with that?
    Genius:
  • Breadman Master
  • 1,280 Answers
Your paddle is probably worn out and has too much play in it. Some play is necessary to get it off for cleaning but it shouldn't be so loose it is coming off during kneading.
Posted on Nov 14, 2010
  • John Szewczyk
    John Szewczyk Apr 14, 2014
    Design flaw Return the machine.
    Welcome Back:
    Visited the website for 2 consecutive days.
I just purchased this 2 days ago and started to use it. I noticed the bread pan would wobble and was noisy during the kneading cycle. On the second use the paddle came off during the kneading cycle. Being a service technician all my life, I started to analyze the problem. I was previously surprised how loose the bread pan fitted into the bread maker and suspected there should be something to support the pan and hold it in place. I could not see anything obvious, but after looking carefully I noticed spring clips on the bottom of the bread pan, and also mating spring clips in the bottom of the bread maker. If I pushed the bread pan down fairly hard into the bread maker the bread pan would snap firmly in place. This stopped the wobbling during the kneading cycle and the paddle coming off. I could not find anywhere in the manual where it explained the bread pan must be pushed firmly down into place until it snaps in. The manufacturer should explain this to their customers on their website.
Posted on Nov 20, 2016
My bread maker paddle is turning correctly, but it is not mixing the ingredients. We put liquids in first. The first time we used it, it was perfect?
You may have too dry or too watery a batter. Check your ingredient mix for accurate measurements.
Recheck the unit without ingredients in place to be absolutely sure you have the paddle seated correctly. Although most are designed to make it very hard to put the paddle on incorrectly, old dough or batter may harden in place and keep the paddle form fully seating correctly.
Mar 01, 2015 | Regal Ware Kitchen Appliances - Others
When I bake a loaf of bread it comes out of the machine with the ceramic mixing paddle baked into the loaf! How do I keep this from happening?
That often happens with bread machines. You can lessen the possibility by using milk in place of water and also choose light crust. This is pretty advanced but if it really bugs you,,, here goes.... After the final punch down and at the very beginning of the final "rise" stage you can remove the dough ball with one hand,( lightly flour your hands first) try to remove the paddle with the other hand from the dough ball and return the dough ball to the center of the pan, and close the lid Just be sure you don't remove your dough ball too early... check your owner manual and be sure you don't remove it BEFORE THE FINAL PUNCH DOWN....!
Feb 15, 2013 | Kitchen Appliances - Others
Kneading blade comes off during breadmaking process
Yes, if the blade come off then your bread is not going to mix and knead properly. The blades on all makers are designed to slip on and off though so you can remove them for cleaning etc. Be sure you are pushing the paddle all the way on. If it still comes off when mixing that would be very odd as the weight of the dough ball itself helps keep paddles on. I have owned dozens of machines by different manufacturers and never had a paddle come off in process.
Jan 01, 2013 | Sunbeam Oster CKSTBRTW20 Bread Maker -...
I bought the bread maker last night and it doesn't seem to mix the dough. I have spots of flour and salt in the dough. It seems like there is a paddle or something that is missing. Do you know if I am...
There is supposed to be a removable small paddle in bottom of pan.
If it's not there, you will not get dough at all. Just wet flour.
If paddle is there, but you have half way dough.. AND you followed directions exactly, machine has a problem. Take it back for refund or exchange.
Nov 17, 2010 | Oster 5838 ExpressBake Bread Maker
Lopsided 1.5 lb loaf
This sounds like a mixing problem. Put all the liquids in the bottom, then the dry, and finally the yeast on top so it mixes last.
After the first mixing, the dough should be a ball with nothing sticking to sides.
MEASURE ingredients carefully!
Verify that the paddle turns freely. If it doesn't, then dis-assemble the paddle and clean bearing and shaft. Lube with foodsafe grease before re-assembly.
Nov 14, 2009 | Kitchen Appliances - Others
My bread machine is not mixing at all even afater a whole cycle 1 hour and 50 minutes any advice (black and decker 2300)
The same thing has happened to me... So the solution is put the machine on # 8 dough, and cook it in your own oven.. I found the #1 did not mix. The dough was all bumps...
Sep 16, 2009 | Black & Decker B2300 Bread Machine
The machine bogs down when mixing the dough for bread
You should be using a dough Hook not paddle I have a Kitchenaid stand mixer and it uses a hook for dough paddles offer too much resistance for dough.
Apr 02, 2017 | Black & Decker B2000 Bread Maker
The paddle will not stay on the shaft while mixing dough.
Probably the paddle and shaft are worn. Both are replaceable. Buy a new Paddle and a Kneader mounting shaft unit (Part No. ADA 29A115)
Panasonic Parts
National Parts Center at 800-332-5368 between the hours of 9:00 a.m. and 8:00 p.m. EST Monday through Friday.
Nov 16, 2008 | Panasonic SD-YD250 Bread Maker
Makes a bad loose sound when mixing dough
My Breadmakers Hearth was making the same sound, so after taking it apart I found that it was only the Bread Pans "under paddle" that the machine reaches up and connects to to drive the Paddle. I wears loose and wobbles and starts to slip making that banging sound. You can either replace the Bread Pan or like I did INVERT the under paddle (requires removing the C-clamp washer) to extend the life of the Pan and use of the Hearth. Hope this helps you.
Oct 20, 2008 | Toastmaster Breadmaker's Hearth 1193 Bread...
Breadman TR444 Bread Maker Logo
561 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
