Question about HP w1907 LCD Monitor
I have Hp w2207h lcd wide screen 3 months ago I found colored vertical line across it (from up to down all the hight) comes and go by pressing on the bottom of its edge , 1 week ago this line comes again with green and white color and it is still all the time when data comes to it , I asked some friends and they told me to clean flat data cable inside it or fix it well , so please help me if this is the right way or there are any other ways (possibilities)? Please help
EPIJAB
  • 89 Answers
SOURCE: HP Color LaserJet 2600n
you probably needt o change the transfer belt which is the "black roller film". you can try wipping it off with a dry lint free cloth.
Posted on Aug 03, 2008
SOURCE: HP Compaq Presario V5000 LCD Problem
I have the same problem. I thought the problem was due to a loose cable so I opened the computer up only to find out the cables are all good. I still haven't found a solution
Posted on Sep 08, 2008
  • 12 Answers
SOURCE: VERTICAL WHITE BAR ACROSS THE LCD SCREEN
Almost certainly the LCD panel has failed, and would be replaced by Dell if it is still under warranty. You can try to replace the VGA or DVI cable that connects the LCD to the PC. If the problem persists it is the LCD.
Posted on Mar 18, 2009
POCBM
  • 121 Answers
SOURCE: 4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Posted on Apr 07, 2009
  • 846 Answers
SOURCE: Vertical lines in my laptop screen
if the lines flicker and change when you put pressure on the screen it sounds defective lcd screen, there are these conductive rubber pieces that lead the signal into the lcd panel and once the connection deteriorates there is no going back. the screen could still be replaced, there are laptop repair places that do it, but you have to have to weigh your options with buying a new laptop, repair could be up to 50% of what your's is worth as a 2nd hand laptop.
you can try to fix it yourself, there are guides online on google and you usually get the screen on ebay for around 150.
Posted on Jun 18, 2009
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Vertical lines but still have a picture.
It sounds to be a T'Con fault. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Defective screen shots to LCD TVs are given with fault details. Try this link too.http://electro-medical.blogspot.com/
Dec 20, 2013 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sir i have a Laptop Compaq M2000.There are 9 Colored vertical line coming on my laptop screen.They are started few days ago.Please tell me what to do.
Well this may be due to the inverter board found behind the LCD panel. Try to press around your screen to see if it stops.
You probably need to solder the loose solder of the coil found on your inverter board.
For this, you need to take the screen apart.
Please do send your feedback.thanks.
Feb 11, 2010 | Computers & Internet
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HP w1907 LCD Monitor Logo
187 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
