Question about Bosch Refrigerators
We have a Bosch built in Fridge freezer model number KIM29473GB/02 (FD8410) and we came home after a couple of days away to find it making a strange noise, ie the motor is trying to start up, you hear a little judder and then it just dies. Then a couple of secs later it tries again and dies again, this was just continuing on and on. The temp selection light was flashing on and off inside the fridge and we couldn't change the temp selection with the selection button. For now we have switched it off and are defrosting it. Any ideas? Thanks
Noggin
  • 944 Answers
SOURCE: AEG fridge/freezer isn't working
This sounds like your fridge has a leak somewhere and it slowly discharged its refrigerant. the compressor can sustain damage when there is no refrigerant and often will hum and eventually fail. Sorry but you may need a new compressor - if you were going to replace the fridge soon anyway then i would go ahead, but a compressor and the labour to fit it etc may be cheaper than a new fridge - you need a refrigeration repair man/shop (if you can take the fridge to a repair shop it will always be cheaper than calling a guy to your house) Sorry i can't really help, but the symptoms are classic, if you are lucky then a technician may be able to fix the leak and restart the compressor, but not always if you want to try something yourself just try tapping the compressor smartly but not too hard with the end of a dry wooden or plastic stick or similar with the fridge plugged in. the compressor is the thing at the bottom in the back that looks a bit like a small fuel tank, should be right in the middle and will be the largest thing in there. Just be careful not to break any copper tubes or touch any wires. Sometimes a stuck compressor can be freed this way, but you will almost certainly still need the leak fixing and a refill of refrigerant. Sorry about the bad news :( Hope this helps :)
Posted on Mar 09, 2007
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GC2224gek admiral freezer keeps defrosting
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Mar 28, 2009
Testimonial: "Thank you for your response. It was the circuit board that was faulty just over a year old. It was replaced just before I saw your email. "
luvmy2vettes
  • 10 Answers
SOURCE: We have a Samsung Fridge,
sounds like the motor is bad. if you have a warranty have him change it regardless if he thinks it is bad. the motor should not be noisy. If no warranty then have him check motor very good. also low refrigerant charge as well as it running too long can freeze it up and stop the fan. most refrigerators are designed to be against the wall this can be a factor in a freeze condition. I hope this helps you!
Posted on Jun 07, 2009
SOURCE: fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Posted on Dec 20, 2009
We have a Bosh KIM29473GB for some time water has been collecting in the bottom tray of the fridge and only takes a few days to fill up, this weekend the freezer stopped working and now nothing works.
If you hear a click every few minutes and a buzz / click then nothing, it would sound as if your compressor is gone, the water problem is the defrost drain pipe is blocked
Oct 06, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice built up in the frost free freezer section
It sounds like the freezer fan(evaporator) is wearing out. This problem is very hard to diagnose because the fan spins but no fast enough to circulated the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Freezers
Bosch KIM29473GB refrigerator lights on but no refridgeration
it sound more like the compressor is faulty siezed up
if so it will try to work then trip on the compressor overheat it will rest for about three to five minutes then try again
if this is happening it almost certainly eliminates the stat if the stat was faulty the compressor would not try to start compressor expensive to replace and time consuming would take about two hours
Good luck
Mar 10, 2009 | Bosch KIM29473GB Bottom Freezer...
Lights on no refrigeration
This may be caused by the thermostat being faulty. To be sure you need to find someone with a volt meter who can check that power is in fact reaching the compressor (freon canister). If it is getting power, then it is possible that the compressor has failed and would need replacing.
Mar 04, 2009 | Bosch KIM29473GB Bottom Freezer...
We have the Bosch kgn34x60 fridge freezer and the fridge wont stay cold. The dial is turned to 5. Any ideas on what might be the problem????? had it less than ayear and the freezer is fine
I have this model and am having the same problem. Bosch don't want to know as it is out of warranty.
This means that a perfectly good freezer has to be thrown away because the fridge won't work properly.
Don't buy Bosch.
Jun 01, 2008 | Refrigerators
Fridge freezer KIM 29473GB/01
Liners are not able to be replaced. Will need to buy a new unit if the liner is a problem.
Oct 07, 2007 | Bosch KIM29473GB Bottom Freezer...
Refrigerators Logo
175 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
