Question about RCA Universal Remote Control
How to turn on subtitles using RCA remote - RCA Universal Remote Control
How to turn off subtitle without a remote on a polaroid tv
Polaroid turn off subtitles tv Questions & Answers - Fixya
www.fixya.com > Forum > Tags > turn off subtitles tv
Polaroid turn off subtitles tv related problems. ... ...subtitles on certain channels? go into menu or setup on remote there ... Not finding what you are looking for?
Nov 17, 2015 | Polaroid Televison & Video
Wich is subtitle buttom fo rca rcrps06gr?
Closed captioning (CC) is enabled/disabled as part of the initial set up process. Subtitles are included in some material and cannot be added or removed.
Dec 13, 2014 | RCA Televison & Video
Turn on subtitles rca universal remote
You do this from the DVD disc set up menu. The same menu that gives you options to choose the chapter or change the sound. It's different for each film or disc. The section of the meniu your looking for is normally called "Set up"
Sep 02, 2014 | RCA Televison & Video
How do I turn on subtitles
That is called closed caption and usually is a menu option on your TV, not the remote.
Jul 02, 2014 | Audiovox RCA RCR3273R Universal Remote...
Technika dv3t
Hi Warren,
Kindly tell him to push the D.SUB button underneath the yellow button, that is if he is on DVD mode. If that one won't work, you may ask him to push the third button from the left hand side of his remote control.
Turning off subtitles will not work for some programs as other broadcasting networks placed restrictions that you cannot turn on/off subtitles using your remote control.
hope this one helps.
Feb 06, 2014 | Televison & Video
I hooked my rca tv and converter box to a rca universal remote as I lost converter remote.My problem isI can only get the remote to turn them both on and off. Wont set up converter box or change channels? ...
Just try some other codes for RCA remote.
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
May 13, 2012 | RCA Televison & Video
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
Can't turn subtitles off
Hmm... have you tried ontop of the remote where it has "tv" vcr" sat" etc...hit tv first then try the menu?and do you have satelite by any chance? because something similar happened to me when i had my old tv put upstairs and hooked up, the remote for it did not work so i had a universal and the tv was on "video 1" input the whole time and the universal remote didn not convert it back to tv so what i had to do was hook up the reciever to the "video 1" port instead of the "tv" input in the back...i hope you get it cause i know it can be a pain in the A$$
Sep 13, 2008 | Televison & Video
Wont turn on
to fix this you have to bye a chep remote and program it to the tv and then turn off the lock ps you can program with the tv off
Apr 06, 2008 | RCA 20F512T 20" TV
Closed captioning
use the one on yoursky remote it has its own subtitles.
Nov 07, 2007 | Durabrand DU1901 TV
Televison & Video Logo
189 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
