Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Icemaker not making ice - feeler arm in up position
I have seemingly the same problem as a least one prior post: Water enters, ice forms, fingers only rotate to drop ice when cube-size "reset" selector button is held for 10 sec. Bucket "feeler" arm never rotates to down position except during reset operation; it's final position is always up...ice bucket full.
Did this problem get solved? If so, please tell me how. Thanks buckets (of ice)?
  • transcapacit Aug 08, 2008
    water enters ice tray and ice cubes are made but you have to continually press gel type reset button to get ice
  • 489 Answers
You may have a broken icemaker and needs to be replaced.  The internal parts are solid state electronics and they can break.
Posted on Sep 30, 2008
No icemaker but makes a noise like when water is drawn to make ice
If the icemaker is still in the freezer, be sure it is turned off (usually OFF is the metal feeler arm locked in the 'up' position) because the unit will still call for water even if the water line is not hooked up...
May 24, 2016 | Kenmore Refrigerators
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
LG LRSC 26920tt won't make ice
In order to determine the problem you must check a few things:
1) Is there water in the ice tray? If not. verify the saddle valve is turned on, check the connection on the water valve, verify that there are no kinks in the inlet hose, and check he water filter to see if it is clogged.
2) Is the temperature correct? Make sure the fans are working properly and air is flowing. Verify the the frig and freezer are at the correct temperature and make sure the ice maker compartment door is sealing shut.
If these things check out ok, run an ice maker test. Make sure the ejector arm and feeler arm are in their original positions before beginning. If they are not:
1. Turn off icemaker and wait 5sec.
2. Turn on icemaker.
3. Wait until feeler arm and ejector are back to original positions.
To begin the icemaker test: Press and hold the test button on the icemaker for 5 seconds. If the LED, feeler arm and or ejector does not return to to their original positions the problem is with the ice maker.
The ice maker part number for your model is 5989JA0002G
Oct 14, 2013 | LG LRSC-26922 Side by Side Refrigerator
Need to know how to turn on ice maker in whirlpool gz25fsrxyy2
Should be a wire feeler arm that runs front to back on that icemaker. If it is stuck in the up position---the icemaker is OFF. It should be hanging downward to be in the ON position. If up---just gentley pull it down until it is moving freely. As the ice bin fill with cubes that arm should move up and down with the icemaker. Once the cube level is high enough for the feeler arm to be held in the up position it will stop making ice until you use enough cubes for the arm to fall again.
Sep 26, 2012 | Whirlpool White Gold 25 cu. ft. ENERGY...
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
The icemaker is not making ice as fast as it would before. It dumps a tray of ice about every 4 hours.
Make sure that there are no kinks in the water line.
Next, inspect the feeler arm of the ice maker and make sure that it is down and not blocked by any ice cubes. If it's raised, it has turned the ice maker off. This arm needs to be in the lowered position to activate the ice maker An over-abundance of ice in the bin will make the arm stay up as a safety feature to keep the ice maker from making more ice than the bin can hold.
Jul 30, 2011 | Refrigerators
GE PROFILE PTS22LHPARWW ICEMAKER NOT WORKINNG
change or remove filter
change control valve
change valve on copper water ine
change copper water line
check input pressure to unit
25? 25? anybody know what is the minimum water pressure supposed to be entering the refrigerator icemaker?
Oct 23, 2009 | GE Refrigerators
MY ICE MAKER FEELER ARM IS STUCK IN THE UP POSITION. CAN YOU PLEASE TELL ME HOW I CAN FIX THIS? MODEL LFX25950SB LG REFRIG
Water is getting into the area where the arm pivots and freezing. This prevents the arm from dropping down when it should. I use a hair dryer to melt the ice in the area of where the arms comes out of the base. As soon as the arm drops, the ice maker will make more ice. This LG in the door icemaker is junk.
Jul 14, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Broken ice maker in a GE side by side refrigerator
Most of the time the spring just pops out of the keeper on the ice maker, If you push the feeler arm back and it does not come back out on its own then the spring has poped off. Look where the feeler arm attaches to the ice maker and there is a round spring between the feeler arm and the icemaker housing. There is one hole in the feeler arm ans one on the ice maker housing that the spring pops into. Its usually the spring is out of the hole on the ice maker housing.
Jun 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Jun 15, 2007 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
1,442 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
