Question about Acer Aspire T135 PC Desktop
My computer turns on but wont show up on my moniter all i did was swith the hard drives n now i tryed to put the origanl back in and its not showing up on my moniter all i need is a diagram of the inside of this modle acer aspire t135
  • 943 Answers
There is only one small problem
this is the fact that your module is probably not in place properly or is covered with dust and as such cannot be properly utilized by the system. all you need to do is pull out the module and clean it(especially the golden panels) then make sure it is properly in place. this should solve your problem.
hope this helped you?
Posted on Nov 14, 2010
Wnen i start my computer my moniter is going to sleep and when i disconnect from cpu it get start and show the cable is disconneted what is the prblem can you give a answer for this particular problem
check whether the pc is running. when it swithes on hear for boot sound. problem can be because of: computer ram failed mother board failed. power supplied failed moniter cable losse connection
Sep 16, 2010 | Computers & Internet
When I swith on the computer,sometimes it can't open,thesystem can run but no visuals.the moniter shows orange light.it is very slow also.
the video (visuals) issue could be a video driver issue.
assuming that you do get something on the screen when you turn the computer on, try to to start your computer in safemode by pressing f8 severval times after you get the first screen, you should see advance startup options. select safe mode and attempt to install an updated video driver (which one depends on your video card manufacturer and model number).
if you don't get any video at all you video card may need to be replaced.
slowness
this is cause by memory wear out or (most likely) malware, now.. you need video and you need to be able to boot into your computer to run some tools that would clean up your system. slowness could also be caused by an old hard drive, if this is the case is better to first get all your data out into a removable hard drive, and replace the hard drive and resintall the operating system.
post back if you were able to get boot up if you have further questions.
Apr 23, 2010 | Intel Computers & Internet
My emachine computer was working then just stopped, when I tried to turn it back on. the moniter is showing no signal received. I have tried checking the VGA connection, changing it out for another, no...
Try your monitor on another machine - if it is working you have operating system/hard drive/motherboard/memory/heating problems. You must work that out if the monitor is good.
Apr 01, 2010 | E-Machines eMachines Desktop PC
When windows starts after some time mouse and keyboard held and moniter shows blue screen giving message problem with HD.and computer become off and when i on it it give message media test failure
Sounds like Hard Drive is failing. You will need to replace the drive. If you haven't done so already, back Up any data you want to keep by moving it to CD, another drive or a second PC.
Hard Drive failiures are pretty terminal so you need to back up urgently or you may lose all your data. If you are in UK, PC World have a disk recovery service for about £95. Elsewhere try a computer store.
Again.... concentrate on getting your data off the current drive. Worry about rebuilding Operating System later.
Dec 17, 2009 | Acer TravelMate 4100 Notebook
My computer often fails to start. even if the hard disk is running my moniter and keyboard doesn't show ant sign of power signal and the moniter screen just remain blank with power led of moniter blinking
Note: make sure that the computer is turned off before removing the RAM from the DIMM slot. Hope this helps.
Sep 27, 2009 | MSI 845 PRO Motherboard
My samsung 923 nw wont display anything!!
check to see if you get image when lowering the resolution, do this with yoru older monitor try to bring it to a basic 800x600 with 16 bit color depth. then switch monitors and see what happens. If this monitor is energy efficient you may want to check on the power savings settings for your computer.
Jun 01, 2009 | Computers & Internet
Maxtor personal storage 3200 problem!!!
First, try another USB Cable. If that does not work properly then I would suspect the box or the drive has failed. If you just bought it, return it to the store and complain. They may replace it. As for your data?
Now if you want to become techie you can remove the hard drive from the box and attach it to you computer either copy the files back if you do not have them on your computer or format the drive if you have your files. Then put the drive back in the box and try to get a refund or buy a different external. I like a metal box with an AC cord plug. Best of luck.
Jun 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hdx avastor drive not seen on pc
please swith of the computer and the hdd connectthe cables then turn on the computer if it dosent detect stilll please right click the my computer and go to manage and then go to diskmanagement in the diskmanagement u should see the hard disk as unalocated or forign .\
then u go to hdd drive if forign please click on the left hand side and say import forign hard disk it shoul work if shows unlocated then u shoul right click on the hard disk name an d say format after formating is over it should get it on the my computer..
Thanks
Nov 10, 2008 | Avastor Computers & Internet
Computer will turn on but wont boot
OK, have you tried checking the connections on your hard drive, afterwards try rebooting. If it still wont boot i suggest you back up data and boot the restore CD that came with your PC. If it still doesn't work , check your BIOS, most BIOS programs have a hard drive auto detection function so if it doesn't show, chances are the problem would be a defective hard drive.
Hope this helps:)
Oct 20, 2008 | Computers & Internet
Qdi motherboard only 200watt power supply hooked up and the 4 12v pin is not hooked up computer turns on but moniter doesnt
you need min 250w power supply with the right connector.
do not try to splice any of the power wire. it will work but you will get burn later.
Oct 02, 2008 | Computers & Internet
Acer Aspire T135 PC Desktop Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
