Question about Intermatic Inc. ST01C Digital In-Wall Timer
I, too, only have 2 wires in my switch. It is not clear what to do with the 4 wires on the utilitech 0192773. Did not see the answer to the same question.
I wrote a page on the Utilitec 0192773
It shows how to wire the timer and shows the manual larger.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Timer-green wire connects to bare ground wire.
Here's what to do Switch has 2 wires.
1) Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. These are the neutral wires. Connect timer-white to these wires.
3) If electric box does not have white neutral wires described above, then connect timer-white to bare ground.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Posted on Nov 14, 2010
  • 1 more comment
  • cranstonf Dec 01, 2010
    what if no red wire from timer to electric outlet what do you with the red timer wire...cap it? (is this for a three way).....please advise....thanks
  • Anonymous Dec 02, 2010
    What timer do you have? If you have Utilitec timer, it is not made for 3-way switching. If you want help, I need more information about switch you are replacing, wires you have and what you are connecting timer to. The first answer I gave explains correct wiring for Utilitec, Woods, GE, Tork, Woods, and Swylight in-wall single-pole programmable timers.
  • Anonymous May 23, 2011
    Information in this answer is 100% correct and tested. Downvote goes out of its way to throw salad on the waiter who has done the research and bothered to answer the question.
Porch light timer switch problem
0192773 is single-pole only.
I think you have wires reversed or attached incorrectly:
http://waterheatertimer.org/How-to-wire-timers.html
Gene h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 31, 2014 | Hardware & Accessories
Utilitech #0192773 setting the timer for not working
I do not have repair for defective timer.
Open following link for clear large-print instructions.
Add a comment about part of manual that does not work, for possible additional help.
1) Timer replaces single-pole light switch only.
2) Timer does not have a battery and must be wired correctly before programming can take place.
3) Choose either dawn-dusk or programmable on-off:
Timer can be set for dawn-dusk operation
-OR-
Timer can be set with 7-day on-off functions of your choice
Aug 18, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Bought a Utilitech #0192773 to replace an older and non-working Intermatic SS7 series. The Intermatic had a black wire connected to hot, and a blue wire connected to neutral, and a red wire was capped off...
Utilitec 0192773 replaces single-pole switch and will not work for 3-way applications.
Open following link for clear wiring and programming steps for Utilitec 0192773
Utilitec can also be tricky to program if you are setting up astro dawn-dusk function.
For others finding this thread, same wiring applies to in-wall programmable timers by GE, Woods, Swilight, Sylvania, Tork, Hagar, UPM, Leviton, Grasslin, Wattstopper, Westek, and Intermatic analog timers. Intermatic battery-operated, Brinks and Aube timers are wired differently since they also work for 3-way applications.
Jun 05, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech Self-Adjusting Wall Timer- #0192773. Unable to program timer. The instructions are so small it is hard to read them
Utilitec 0192773 is also listed as LW60419
1) Has optional daylight savings plus dawn to dusk programming
2) Electrical wiring must be connected in order to program timer. This is because timer is powered by electric circuit (instead of battery).
3) Program choices:
-Individual days MO TU WE etc
-All 7 days of week
-Weekdays
-Weekends
4) Large manual + wiring tips:images load slow with dial-up
5) Enlarged manual
-Click on image to enlarge
-For more size, hold down Ctrl key on keyboard and use scroll-wheel on mouse
Sep 30, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Only 2 black wires on current switch - Utilitech 0192773 has 4
Webpage explains wiring and has large print:
Mar 07, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
363 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
