Question about Yamaha RX-V550 Receiver
Yamaha rx-v550 not turning on and no lights showing. Have checked fuses and they are fine
  • 236 Answers
SOURCE: yamaha receiver model rx-v550
it is your protection circuit working, preventing the unit from any further damage to circuitry. you can check first your speaker cabling for any short connections, possibly red/black terminal wires got entangled. if all ok then try removing all speakers then turn on the amp. if still does the same thing turning off then you have a problem with the amp output stage, shorted power output transistrs/driver probably. if the unit turns on normal without the speakers then you must have one or both of your speakers busted. by the way this amp is multi channel, after removing ALL the speakers connected, and does not turn off anymore, put the speakers back one by one and observe if the unit with turn off and on which set of speakers. otherwise if still trips even without the speakers, it is your amplifier that is deffeective, any of the five channels, main, rear,center. let me know result so i can guide you on how you can get it repaired and what will be the extent of damage in case.
reden
Posted on May 22, 2008
SOURCE: power can not turn on for Yamaha RX-V520
If you can desolder the audio amplifier IC to check the device turn on,If the device turn on with the audio amplifier IC desoldered you need to change him.
Posted on Jun 12, 2009
  • 53 Answers
SOURCE: Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
Posted on Nov 07, 2009
tvservice306
  • 458 Answers
SOURCE: Yamaha RX-V660 Display Light Out
if you not tech ..suggest send to service
this problem is display negative voltage missing......or display driver ic bad.....
Posted on Nov 11, 2009
ProColorTV
  • 25 Answers
SOURCE: need an drawing showing hou to connect yamaha rx-
Hell Fixya customer,
Here are two links for the Yamaha receiver, and the Sony user manuals.
Please look through them concerning your specific hookup. If you still have questions or need help, please let me know.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V430e.pdf
http://www.sony.com.au/support/product/kdl-52z5500
Thank you for using Fixya
Posted on May 01, 2010
Does yamaha rx-v550 reciever have intigrated amplifier
Yes, by definition a receiver is a combination of a tuner and an amplifier in one chassis.
Mar 09, 2015 | Yamaha Audio Players & Recorders
Rx-v550 receiver. Can't find a way to make the headphones and speakers on at the same time. Tried setting SP Zone B permanual, and only headphones work.
Generally speaking a receiver will power either the speakers OR the headphones. It is rare for you to be able to have both. The insertion of the headphones interrupts the signal to the speaker section. There are headphone amps available which would allow you to use the tape-out section of the receiver to get a signal to the amp wihtout effecting Zone B.
Dan
May 23, 2011 | Yamaha RX-V550 Receiver
I want to connect a phono turntable to my RX V550. any suggestions?
No can do without an intervening phono preamp.
Check out eBay for one or, if you still have an older stereo receiver with a Phono input hanging around, use it to preamplify the TT and run an RCA pair from the Tape Out to any available stereo input on your Yamaha.
Dec 26, 2009 | Yamaha RX-V550 Receiver
I have two Component Video products (DVD and Cable Receiver) plugged in but can't get the DVD to work. How do I switch from one to the other? This is for a Yamaha RX=V550
Inputs on your receiver are assignable. Assign one input to DVD function and other input to DTV/CBL for example. Refer to page 49 of your manual for instructions.
Dec 05, 2009 | Yamaha RX-V550 Receiver
Nov 06, 2009 | Yamaha RX-V550 Receiver
My front main speaker channel is no longer working. The fuses on the power side are intact. There was no obvious time of failure. anything else i should check?
I know this sound silly, but, have you checked the tini tiny button on the front of the receiver that says A/B on it in microscopic letters? other than that, not much else to check. It happens all the time! Hope this helps.
Sep 26, 2009 | Yamaha RX-V550 Receiver
Yamaha receiver rx-v661 display light is out
lamps are burnt out or missing power to backlight system.
please check all the fuses.
nuwan.
Jan 13, 2009 | Yamaha Audio Players & Recorders
Yamaha receiver model rx-v550
reden
May 22, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V550 Receiver Logo
353 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
