Question about GE WCVH6260F Front Load Washer
Where is front loader pump located, washer wont drain water, cleaned the filter ,want 2 look at pump 2 c if its good, cant find it
  • GE Master
  • 3,051 Answers
You simply take the 3 screws out from under the front lip. AND THE PUMP IS SITTING RIGHT THERE IN FRONT OF YOU SHOULD LOOK LIKE THIS
put a cake pan under the lip of the drain and unscrew the filter to take out the stinky water. Once it won't unscrew anymore pull the filter out and clean. OR PULL THE ENTIRE PUMP OUT TO PERFORM A INSPECTION OF THE PUMP
Posted on Nov 17, 2010
Is there a filter on this model
Of course. The filter is located in the pump behind 'front' bottom panel. Disconnect power, remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Be prepared for a lot of water, catch it in something to prevent more work. Clean the filter from any debris that prevents water from draining out properly. Front loaders hv filters, top loaders don't. Don't forget to click that you are helped!
Oct 18, 2014 | Maytag EPIC MFW9700S Front Load Washer
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
Front loader stuck in final spin - not draining
Very likely the reason your washer isn't draining is because the filter screen on the drain pump is blocked so it cant drain, its a fairly common thing wrong with those type front loaders soi have written this tip covering how to clean that filter, http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
Lg tromm front loader will tumble but wont spin
Open the access door at the bottom left corner of your washer. Use the small hose there to drain the remaining water from the machine. Un-screw the big knob next to it and pull out the attached filter. Clean out the filter and re-install. If the filter was clear, replace drain pump motor.
Mar 15, 2011 | LG WM2277H Front Load Washer
Wont drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For most front loaders:
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the bottom toe panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
You could also check the exit hose of the washer for blocks. Next snake out your wall drain, it helps.
Jun 12, 2010 | Samsung WF337AA Front Load Washer
I was given a kenmore quei pack 2 washing machine.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not cleaning clothes
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Try using powders for 'front loaders'
Apr 05, 2009 | Kenmore HE2 Plus Front Load Washer
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
GE WCVH6260F Front Load Washer Logo
162 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
