Question about NEC Electra Professional ETW-16DC-2
Name display how do you program names in phone display?
You need to do this from the main unit. Press Feature then Hold, then #0*. You will be in Program Mode. Then press Line 4. Then press 10, then you can scroll through the ports & names. You have to change the 10 in the sequence on the screen to an 18 (do this by using the * button to scroll backwards). Now, my problem is, I am here, but cannot get the buttons to spell out names?
Posted on Jul 14, 2008
How do I get my Mail Box name & displayed name to change for Nortel phone system
The administrator or tech needs to do this from Administration programming (FXXXDMIN), see your office admin or call the tech in for admin training.
Password required as well which the vendor/tech can help with.
If you know password and how to do programming then looks under Sets/***/NAME
Dec 05, 2012 | NorStar T7316E Corded Phone
I am trying to change the names that appear on my phones i.e. people who have left but names still appearing
To change the names in the telephone system you'll need to enter programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Jan 19, 2011 | NorStar BCM-T7208 Corded Phone
How to change name displyed on norstar T7208 & T7200 tele phone
To chane the name on the sets you'll need to enter telephone programming.
Oct 28, 2010 | NorStar T7208 Corded Phone
I would like to change the display names that are attached to each line. How do i do this?
The display should say Lines.
The display should ask for a line number
Press the list soft key
The display should say Line001 and the line name. if this is the line name you want to change... Press the show key (top right arrow)
The display should say Name
Press the show key (top right arrow) .
Enter in the new name for the line
Press the next key (bottom right arrow) . If you want to program additional line names press the heading key(top left arrow) till you see "Line 001; new name" and press the next key (bottom right arrow) repeat the procedure for the additional lines
press the Rls key when finished
Jan 29, 2010 | NorStar M7310 Corded Phone
How do I change the display name on incoming line
You would have to go into program mode.
program 93-1 would do the trick.
Tony
Ameritel
732.477.7733
Jul 09, 2009 | Toshiba DKT-2020 Corded Phone
Unable to program buttons on the phone
r u using CTX/CIT system??
this only apply for CTX/CIX
to set extn ket at flexible button
press  #9876
press  HOLD
press the flexible button u wanted to assign
press 610 follow by extn number
press again the plexible button to confirm
repeat step for other flexible button
to set name must go to administrate phone
press MODE at the display
press ADMIN
key in password
default password are ' 0000 '
press HOLD, display will show phone name
press HOLD, again will show DN ID
DN stand for extn
key in extn number then key in name
HOLD again to confirm setting
repeat step for other name
May 26, 2009 | Toshiba DKT-2020-SD telephone
Change name that comes up on display phoned
Name programming requires access to system programming. If you go to the main phone and, without picking up the handset, press PROG and dial **1234 and ENTER, it will go into programming mode. Dial 004 and you are looking at the Ext Name screen. An ENTER at this point starts at 101 OPERATOR (default). Now just start pressing the letter keys and the right arrow to spell out the names. The keys press 7 times for ABCabc2. Punctuation and special characters are under the 1 and 0 keys and STORE or ENTER saves your work.
When I install my systems, I let everybody have access to the programming by class of service. You may be able to program from any phone in your system, it depends on the installer. The phone that rings when you dial "0" is probably the main phone if you can't program this from your own phone.
PROG exits programming.
Carl
Mar 11, 2009 | Panasonic KX-T7630 Corded Phone
Name display
you need to get into program mode to change the display name.
It also depends on the type of system.
ldtsnj.com
Oct 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Extention Display Name
This detailed instruction is not in the small book that came with the phone. It will be found in the binder or full sized publication titled “User Manuel’ for the models KX-TD816 and KX-TD1232 that came with the phone system.
You will want to use the overlay that DID come in the smaller book. You will place it on top of the buttons and it will provide programming commands listed in the instructions.
Page 71 has the “Getting into programming” details.
[Program], **, 1234
Now you are in user programming mode.
Page 87 will instruct you how to program names.
Press 004, [Next], [jack number] (ext 101 = jack #01-1, ext 102 = jack #02-1 ect…)
Once the jack and the old name are displayed, press [Clear] and then start pressing the letters according to the “Overlay”. (3 = 3 D E F) press the S-button that displays the correct character. S-buttons are the 3 buttons directly below the display. When you are done press [Store] and you can press [Next] to se more jacks or just exit by pressing [Program].
Jun 20, 2008 | Panasonic KX-T7453 Corded Phone
Change home screen display
Press the * key to switch back to date and time. Also, the SHIFT button on top will change the STA EXT FEAT.
The only way I know of changing the name is in the main phone system.
Apr 23, 2008 | Panasonic KX-T7453 Corded Phone
NEC Electra Professional ETW-16DC-2 Logo
126 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
