Question about GE 27GT620 TV
How can I run the audio from the tv through my receiver/amp and speakers ?
    President:
  • 2,992 Answers
You can't, at least not from the TV directly. This set doesn't have any audio output jacks for connecting to an external amplifier. If you're using the TV all by itself, on a cable system without a converter box, for instance, there's nothing you can do. But if you're using a cable box, satellite receiver or other set-top box, you could run the audio output from that device to the amp and turn the volume down on the TV. In this case, you're not running the sound from the TV to the amp; you're running the sound from the source to the amp and just using the TV as a video monitor, but the result is the same.
Posted on Nov 14, 2010
How to connect receiver to TV for sound
Does the TV have an audio ear phone jack? if it does get an audio jack that fits the TV Audio out Phone plug. Then connect it to an Audio Amplifier that would run the speakers.
This is one way...or you can solder onto the speaker weirs and run that to the audio amp that is connected to the wall spekers.
Feb 03, 2014 | Audio Players & Recorders
How to connect a samsung soundbar to my tv and sat and dvd
Feed the audio from the audio out on your tv to the receiver. Plug your sound bar into the speaker output of the receiver and you should be up and running. You will have to turn on the receiver and control the audio there. The TV may have a setting for external speakers that you need to turn on in the audio menu. Now this is the straight forward approach but there are many factors to consider. One example would be the amplifier output being compatible with your speaker so you don't blow the speaker or the amp or amp/receiver combo.
Sep 28, 2012 | Samsung Hw-e450 Air Track Soundbar
We cant find the right cords or hookups to our speakers and how do they hook up to your tv
Speakers don't hook directly to a TV unless your TV is unique and has its own amplifiers (not likely). Speakers are driven by amps, amps are usually inside a receiver and IT would connect to your TV to receive sound program. However, the TV usually has serious audio limitations (or we wouldn't need receivers and after-market speakers, right?) so why not get the audio IT monitors from the source itself and conenct it directly to the controlling receiver, which specializes in audio?
Aug 29, 2010 | Theater Research TR-2810 Main / Stereo...
Yamaha av Receiver RX-V465 picture but no sound. Can switch between PS3 and sat tv all via hdmi connections. Good picture yet still no sound. Trying to run left right and center Bose speakers. Read the...
Check the settings on receiver in the SETUP menu / HDMI / Audio. Here you can choose Amp (sound goes from the speakers connected to receiver), TV (receiver is muted and sound is routed via HDMI to TV) and Amp+TV (sound goes from speakers and also to TV).
Also check in OPTION menu / Signal Info that receiver is receiving sound in recognized format.
Jul 04, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
My TV has audio (left & right) & video jacks (red,white &yellow) can I connect my Kenwood KR-V5580 to it for stereo sound If so what do I connect it to video 1 or 2, phone,etc
Audio can usually go either way to a TV. In or Out. Why someone would want to hear external audio through a TV's marginal audio electronics and speaker(s) is beyond me, but sometimes that is what they want.
Take the audio from the receiver via whatever unused Tape or Video function connectors you like to the TV's Audio L & R IN. Anything the receiver processes will be audible through the TV as long as you DON'T select that function for listening on the receiver.
Listening to TV-related audio through the receiver and its (presumably better) speakers makes much more sense, but again, the TV's marginally audio capabilites place a serious limitation on sound quality expectations. In your case, stereo is as good as it could be.
If your TV has Audio Out jacks, just run them to any convenient Line Level input (NOT Phono). If your TV has internal audio controls for volume, set it to Fixed so the TV's volume control doesn't affect the sound going out to the Kenwood.
A better TV-related audio solution would be to connect the BEST audio of whatever source you're watching directly from that source to the receiver. Cable, DVD/BD, SAT always have 2-channel analog RCA connectors as well as (unusable on the Kenwood) digital audio outputs.
VIDEO from the Kenwood to the TV:
You describe your TV having Composite (3 -RCA-style cables). The Kenwood is limited to Composite (Lower-quality, single Video RCA-style cable). Check your TV for a single Video In connection and run THAT from the Kenwood's Monitor Out so you can pass other video through the receiver.
In its day this receiver was pretty high-end but to really enjoy modern multichannel audio from video sources you might consider an upgrade to a true multichannel Audio Video Receiver. For one thing it would support digital audio and probably Component and HDMI video. You could still use the Kenwood's amplifiers to drive speakers or as a secondary system.
Apr 29, 2010 | Kenwood KR-V5580
Hdmi connection from receiver to hdtv, with set top cable box and no sound from speakers
Check your HDMI sound settings. You can choose it HDMI sound should go to receiver+speakers or to TV.
It is in menu: Setup / Func. setup / HDMI Audio. Options are: Amp / TV / Amp+TV.
Dec 25, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX V463 AV Receiver-I have an LG digital LCD tv and hooked up the two up by HDMI and an optical cable. I Only get sound from the right front and the subwoofer The Rest of the 4 speakers have no...
If you're getting audio out of one speaker, it's likely not an issue with how the TV's connected to the receiver, but an issue with how your speaker's are connected.
If you run a "speaker test", do you get audio out of all your speakers? If not, it's likely you mixed up your positive and negative connections when connecting your speakers.
Mar 19, 2009 | Yamaha RX-V463 Receiver
No audio sound from HDMI connection from TV to Onkyo 606 amp.
you have the output of the receiver going to the input of the TV?
i believe that you should be running the TV output to the receiver input to get your sound from the TV to the receiver and thus speakers.
the easiest setup is to just run your cable box and DVD player HDMI's into your TV inputs. then run another HDMI from the TV output to the receiver input.
Feb 28, 2009 | Onkyo TX-SR606 Receiver
Can't get audio from HD TV to run through Yamaha receiver speaker
be more specific!...how is the tv hooked up? hdmi, component, straight to the tv, or into the amp then tv?....what audio out? optical, digital? also what are you trying to view? local programming? cable/sat? dvd? your best bet is to ignore video on the amp and go straight to tv. can't help u more until i have more specifics.
Jan 14, 2009 | Yamaha HTR-6130 Receiver
Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Nov 29, 2007 | Onkyo TX-SR605 Receiver
Televison & Video Logo
76 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
