Question about Kenmore 22422 Top Load Washer
Washer fills up with water. and does nothing else. what can be wrong.
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description "washer fills up with water. and does nothing else" it sounds like you`ll need to replace the lid switch, but first...
Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...especially those built in the past 1-2yrs. the complete model number would distinguish if it applies to your particular model )
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the agitate or spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
Good luck.
Regards,
Macmarkus :)
Posted on Nov 14, 2010
Washer not spinning
PCB has failed possibly or lid /door switch
Feb 24, 2018 | Whirlpool Washing Machines
Washer acts as though it is not even plugged in. Does absolutely nothing. How do I check to see if power is getting to the machine. nothing wrong with outlet or power supply.
Check something simple like the beginning of a cycle where the water fills the washer. You should at least hear the solenoid click on.
Jul 20, 2011 | Kenmore 14102 Top Load Washer
D/washer fills with water rinses when heating shorts out house
If this machine has been installed and worked for a while, are you sure nothing else has been pluged into the same circuit as the dishwasher and overloading it. If the element is actualy heating up I doubt anything is wrong with it to kick out the breaker. Check out what other stuff goes out with the breaker off.
Oct 29, 2009 | Maytag 24 in. MDBH970AWS Built-in...
My washer keeps filling with water even after the cycle is going. I put it on small load, it fills to the right level for a small load, the cycle begins and soon the washer is overflowing. Even after final...
hi there......wow !! your using a lot of water...sounds like you have a failed inlet valve resulting in water flowing continually into the machine.....remedy relace the inlet water valve
regards Sir Galahad
Aug 12, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Kenmore 110 Washer fill hoses flowing the wrong way...
Both hoses must be connected to a valve or capped off.
Jun 08, 2009 | Kenmore Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Kenmore 22422 Top Load Washer Logo
731 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
