Question about Whirlpool GU2400XTP Built-in Dishwasher
My phillips e5 16 dishwasher stopped after filling with water... any ideas?
I have a samsung dms500tr dishwasher that turns on, starts the program but will not fill with water. we have checked filter and all are clear
The water inlet valve has stopped working. It is an electric magnet valve. located in the bottom of the machine, remove the side panel where the water hose comes in and follow the hose to the valve. Shut off the water supply and remove the valve, note how the wires are connected. Buy a new valve and replace. No special tools are required. A Phillips scewdriver a straight screw driver and a pair of pliers are a that is required.
Dec 04, 2011 | Samsung Dishwashers
I have a Kenmore dishwasher, not sure of the model or year (less than 10 years old) but water constantly flows into the dishwasher. So much so that it leaked all over the floor because the bottom filled up...
Hello.
If it's filling all the time when dishwasher is not even running? The water inlet valve that the house water supply connects to at the dishwasher,is sticking open and needs to be replaced..what you can do now to stop it from constantlu filling is turn off water supply to the d/w from under the kitchen sink.
Typically the model number is on a label on the egde of the door inside or on the rim of the tub..it would be needed to order a water valve
Gene
Aug 24, 2011 | Dishwashers
Bosch smu4096ud /14 dishwasher wont fill with water
Find out where the water is being stopped. Firstly at the wall. Then maybe at the solenoid (depending on the model) and then just trace the water line until you find out where it's being stopped.
Also I would recommend you run some nickel safe ice machine cleaner through the system to get rid of the 'white junk'.
Mar 11, 2010 | Dishwashers
My GE Nautilus dishwasher takes water in and then stops and nothing happens. I tried flusing it with hot water and vinegar and no progress. Any ideas are very welcomed. Thank you.
Flushing the hose with hot water and vinegar would not help.
If the machine is filling and then stops, parts that may be responsible are the impeller pump and the control board.
If the machine is under filling, test also the floater switch.
If the water is not warm, check the heating system or the hot water supply.
If this machine has dual inlet, test that both solenoids are opening.
Dec 02, 2009 | GE Dishwashers
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Dishwasher does not wash
If you are saying that in the wash cycle it fills and then stops it could be that your water temp is too low. Some models will stop to heat the water in the main wash before going into the agitate mode.
Apr 07, 2009 | Dishwashers
Hi there I have a Zanussi zdf121 dishwasher which is only doing a cold wash, not heating at all. Not sure if its hot fill but the hot water is fine elsewhere. Any ideas please Pete
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
Mar 02, 2009 | Zanussi 18 in. DA4342 Free-standing...
Will not fill up with water
Clogged ore bad water inlet valve. It's called a star head screw. buy a star bit.
Nov 22, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Whirlpool GU2400XTP Built-in Dishwasher Logo
70 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
