Question about Maytag Neptune MAH5500B Front Load Washer
How do I install stabilizer bolts? - Maytag Neptune MAH5500B Front Load Washer
Steps to replace 2007 dodge dakota tront shocks from strut spring assembly
Hello Russell,
If you replacing the front struts as an assembly the springs will be equipped and ready to install.
If your purchasing the strut assembly without the coil springs you will need a spring compressor.
  1. Before servicing the vehicle a service manual for safety precautions should be consulted.
  2. Raise and support the vehicle.
  3. Remove the tire and wheel assembly.
  4. Support the lower control arm outboard end.
  5. Remove the upper shock nuts.
  6. Remove the stabilizer link lower nut and then separate the stabilizer link from the lower control arm to gain access to the lower shock bolt.
  7. Remove the lower shock bolt.
  8. Remove the shock.
To install:
  1. Install the upper part of the shock into the frame bracket.
  2. Install the nuts. Tighten to 45 ft. lbs. (61 Nm).
  3. Install the lower part of the shock into the lower control arm. Tighten the bolt to 155 ft. lbs. (210 Nm).
  4. Install the stabilizer link lower nut to the lower control arm.
  5. Remove the support from the lower control arm outboard end.
  6. Install the tire and wheel assembly.
  7. Remove the support and lower the vehicle.
Jul 27, 2016 | Dodge Cars & Trucks
I have replaced the stabilizer links on my 2008 Pontiac G6 base model and I cant find the torque specs for the nuts.
Thanks for using FixYa.
Stabilizer Links
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the front tire and wheel assembly.
  3. Disconnect the stabilizer link from the stabilizer shaft.
  4. Disconnect the stabilizer link from the strut assembly and remove from the vehicle.
To install:
  1. Connect the stabilizer link to the strut assembly.
  2. Tighten the stabilizer link nut to 48 ft. lbs. (65 Nm).
  3. Connect the stabilizer link to the stabilizer shaft.
  4. Tighten the stabilizer link nut to 48 ft. lbs. (65 Nm).
  5. Install the front tire and wheel assembly.
  6. Lower the vehicle.
Mar 04, 2011 | Pontiac G6 Cars & Trucks
My rack and pion is leaking , how do i replace
To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section. NOTE: The wheels of the vehicle must be straight ahead and the steering column in the LOCK position before disconnecting the steering column or intermediate shaft from the steering gear. Failure to do so will cause the SIR coil assembly (clock spring) to become uncentered, which may cause damage to the assembly.
  2. Lock the steering column by installing the J42640 into the underside of the steering column.
  3. Raise and support the vehicle.
  4. Remove the tires and wheels.
  5. Remove the power steering gear heat shield.
  6. Remove or disconnect the following: CAUTION
    Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control, which could result in personal injury.
    • Intermediate shaft lower pinch bolt and coupling from gear
    • Pressure and return pipes from the gear
    • Electrical connector, if equipped
      Stabilizer shaft links at lower control arms
    • Remove the left stabilizer shaft insulator.
    • Rotate the stabilizer shaft to access steering gear bolts.
    • The outer tie rod retaining nuts.
    • Using J24319-B separate the outer tie rods from the steering knuckles.
    • Rack and pinion attaching bolts
    • Rack and pinion assembly through the left wheel opening.
  7. Transfer the outer tie rods if replacing the power steering gear.
To Install:
  1. Install or connect the following:
    • Rack and pinion assembly through the left wheel opening and tighten the bolts to 70 ft. lbs. (95 Nm)
      Pressure and return lines to the steering gear and tighten the fittings to 22 ft. lbs. (30 Nm)
    • Heat shield and bolts. Tighten the bolts to 7 ft. Lbs. (10 N)
    • Install the left stabilizer shaft insulator.
  2. Install stabilizer shaft Links to lower control arms
  3. Intermediate shaft to the steering gear and tighten the pinch bolt to 35 ft. lbs. (47 Nm)
  4. Install the outer tie rods to the steering knuckles.
  5. Install the outer tie rods retaining nuts. torque the nuts to 22ft.lbs(30 Nm) plus an additional 180 degrees.
  6. Install the tires and wheels.
  7. Lower the vehicle.
  8. Remove the steering column anti rotation pin from the steering column.
  9. Fill and bleed the power steering system.
  10. Adjust the front toe.
Lock the steering column by installing the Steering Column Anti Rotation Pin tool J 42640 into the underside of the steering column--Aurora
Steering gear mounting bolts--Aurora
Power Rack & Pinion Steering Gear Heat Shield Removal & Installation To Remove:
  2. Remove or disconnect the following:
    • The stabilizer shaft links.
    • Rotate the stabilizer shaft downward.
    • The electrical harness clip.
    • Power steering gear heat shield mounting bolts.
    • The heat shield.
To Install:
  1. Install the power steering gear heat shield.
  2. Install or connect the following:
    • The mounting bolts And torque to 89in.lbs.(10 Nm)
    • Rotate the stabilizer shaft into position.
  3. Lower the vehicle.
Figure of heat shield removed from above rack bolts with location shown
Feb 11, 2011 | 2001 Oldsmobile Aurora
Remove and replace Front Sway bar
Hello ggagne.
Here is the procedure.
  1. Raise and suitably support the vehicle.
  2. Remove the left tire and wheel assembly.
  3. Remove the pinch bolt from the lower intermediate steering shaft
  4. Loosen all insulator clamp attaching bolts.
  5. Place a jack stand under the center of the rear frame cross member.
  6. Remove the rear frame-to-body bolts.
  7. Lower the rear of the frame just enough to gain access to the stabilizer shaft.
  8. Remove the insulator clamp bolts and the clamps from the frame.
  9. Remove the insulators from the stabilizer bar.
  10. Remove the stabilizer bar links from the control arms.
  11. Pull the stabilizer shaft rearward.
Installation
  1. Insert the stabilizer shaft to the left side of the vehicle. Important: DO NOT tighten the stabilizer link nut at this time. The weight of the vehicle must be supported by the control arms such that you can obtain the vehicle design trim heights before tightening the link nut.
  2. Loosely install the stabilizer shaft link at the control arm.
  3. Install the insulators on to the stabilizer bar.
  4. Connect the insulator clamps to the frame.
    • Tighten the stabilizer shaft bracket bolts to 48 Nm (35 ft. lbs.) .
  5. Raise the frame into position while you guide the steering shaft onto the gear.
  6. Install the new frame-to-body attaching bolts.
  7. Remove the jack stand.
  8. Install the pinch bolt and tighten.
  9. Install the left tire and wheel assembly.
  10. Lower the vehicle.
  11. Support the weight of the vehicle by the control arms.
  12. Tighten the stabilizer link nut.
    • Tighten the stabilizer shaft link nut to 23 Nm (17 ft. lbs.)
There you are, I hope your job goes well.
Thank you for using FixYa.
KL
Nov 13, 2010 | 2002 Buick Century
How to replace a sway bar end links to a 94 intrepid
REMOVAL & INSTALLATION
The rear suspension on LH platform vehicles is a fully independent suspension. A stabilizer bar (also called a sway bar) is mounted in rubber isolator bushings and connects the rear struts through links. Note that the fuel tank must be removed to remove the stabilizer bar.
CAUTION OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
  1. Disconnect the negative battery cable. Relieve the fuel system pressure.
  2. Raise and safely support the vehicle.
  3. Remove both rear wheels.
  1. Position a transmission jack under the fuel tank just forward of the crossmember to help support the fuel tank when crossmember is removed.
  2. Remove the four crossmember to frame rail attaching bolts. Remove the fuel tank.
  3. Remove the stabilizer bar to link assembly attaching nuts and remove the bar and isolator bushings as an assembly from the vehicle. Inspect the isolator bushings for damage or excessive wear and replace, if necessary.
To install:
  1. Inspect for broken or distorted retainers and bushings. If bushing replacement is required, replacement bushings can be installed by locating the split in the bushing, prying open and removing the defective bushing from around the stabilizer bar.
  2. Install the stabilizer bar and isolator bushings back into the vehicle as an assembly making sure bar is centered in vehicle so it doesn't contact other suspension components.
  3. Install stabilizer bar attaching link onto stabilizer bar. Install new link to bar attaching nuts and tighten to 70 ft. lbs. (95 Nm).
Replace the sway bar bracket bolt with new after loosening or removing them. Only use original equipment bolts as replacements.
  1. Install the fuel tank back onto the vehicle.
  2. Position the crossmember on frame rails and install four mounting bolts. Tighten attaching bolts to 70 ft. lbs. (95 Nm).
  3. Remove transmission jack from under the fuel tank.
  4. Install the rear wheels and lug nuts. Tighten the lug nuts, in a star pattern sequence, to 95-100 ft. lbs. (129-135 Nm).
  5. Lower the vehicle. Reconnect the negative battery cable.
  6. Pressurize the fuel system and check for leaks.
  7. Check and reset the rear wheel toe to specifications as required.
Jul 03, 2010 | 1994 Dodge Intrepid
Replace broken sway bar for a 1996 ford windstar
Section 04-01: Suspension and Wheel Hubs, Front 1996 Windstar Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise and support the vehicle. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the 6 mm drive hole in the front stabilizer bar link ball stud, do not use an Allen wrench to break loose or tighten or final tighten the front stabilizer bar link-to-shock absorber nut.
    Using care not to damage the front stabilizer bar link ball stud seal, remove the RH and LH front stabilizer bar link-to-front shock absorber nut.
  1. Using care not to damage the front stabilizer ball link stud seal, remove the RH and LH front stabilizer bar link-to-front stabilizer bar nut.
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage the ball joint boot.
    With another set of support safety stands under front sub-frame, remove two rear sub-frame retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar bracket bolts, stabilizer bar brackets, stabilizer bar bracket insulators and front stabilizer bar (5482) as required.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar bracket insulator installation position.
  1. Lubricate inside diameter of new stabilizer bar bracket insulator with Rubber Suspension Insulator Lube E25Y-19553-A meeting Ford specification ESF-M99B112-A or equivalent. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber stabilizer bar bracket insulators.
  1. Install new stabilizer bar bracket insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on stabilizer bar bracket insulators and install new bolts. Tighten to 55-63 Nm (40-46 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Tighten to 115-132 Nm (85-97 lb-ft).
  1. Install front stabilizer bar link (5K483) to front shock absorber. Use care not to damage link ball joint boot seal.
    Install a new front stabilizer bar link-to-shock absorber nut. Tighten to 90-100 Nm (66-74 lb-ft).
Apr 28, 2010 | 1996 Ford Windstar
Replace swaybar 1999 silverado
  2. Remove the tire and wheel.
  3. Remove the stabilizer shaft nut from the link bolt.
  4. Remove the stabilizer shaft link bolt.
  5. Remove the stabilizer shaft link insulators and spacers.
  6. Remove the oil pan skid plate, if equipped.
  7. Remove the stabilizer shaft insulator bracket bolts.
  8. Remove the stabilizer shaft bracket.
  9. Remove the stabilizer shaft.
  10. Remove the stabilizer shaft insulators.
  11. Inspect all of the parts for wear and damage.
To install:
  1. Install the insulators to the stabilizer shaft.
  2. Install the stabilizer shaft.
  3. Install the brackets over the insulators and the stabilizer shaft.
  4. Install insulator bracket bolts and tighten to 37 ft. lbs. (50 Nm).
  5. Install the stabilizer shaft link insulators and spacers.
  6. Apply Loctite® on the threads of the stabilizer link bolts then install the bolts.
  7. Install the stabilizer shaft nut to the link bolt and tighten to 89 inch lbs. (10 Nm), and continue to tighten the nut until 2-4 threads protrude above the nut.
  8. Install the oil pan skid plate, if equipped.
  9. Install the tire and wheel assembly.
  10. Remove the safety stands
  11. Lower the vehicle.
Mar 30, 2010 | 1999 Chevrolet Silverado 2500
Corvette sway bar installation
Stabilizer Bar: Service and Repair
Front
Removal Procedure
1. Raise and support the vehicle. Refer to Vehicle Lifting.
2. Remove the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation.
3. Remove the stabilizer shaft link nuts from the stabilizer shaft.
4. Remove the stabilizer shaft insulator clamps from the front crossmember.
5. Remove the stabilizer shaft from the vehicle.
Installation Procedure
1. Install the stabilizer shaft, insulator clamps and bolts to the crossmember.
2. Install the stabilizer shaft links to the stabilizer shaft.
Notice: Refer to Fastener Notice in Service Precautions.
3. Install the stabilizer shaft link nuts.
- Tighten the stabilizer shaft link nuts to 72 Nm (53 ft. lbs.).
4. Install the stabilizer shaft insulator clamp bolts.
- Tighten the stabilizer shaft insulator clamp bolts to 58 Nm (43 ft. lbs.).
5. Install the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation.
Rear
Removal Procedure
4. Remove the stabilizer shaft clamps, bolts and nuts retaining the shaft to the crossmember.
1. Install the stabilizer shaft to the vehicle.
2. Install the stabilizer shaft insulator clamps to the stabilizer shaft and the crossmember.
- Tighten the stabilizer shaft insulator clamp bolts to 65 Nm (49 ft. lbs.).
- Tighten the stabilizer shaft insulator clamp nuts to 95 Nm (70 ft. lbs.).
3. Install the stabilizer shaft links to the stabilizer shaft.
4. Install the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation.
Oct 30, 2009 | 2001 Chevrolet Corvette
Front Sway bar(Stabilizer bar)
please give good rating if this helps
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise vehicle on a hoist. Refer to Section 00-02 .
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut, or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Remove and discard nuts retaining stabilizer bar link (5K484) assembly to front stabilizer bar (5482) and front shock absorber (18124) with an 8 mm closed-end wrench and an 18 mm open-end wrench.
  1. Remove nuts retaining steering gear (3504) to front sub-frame, and move steering gear off the front sub-frame.
  1. With another set of support safety stands under front sub-frame, remove two rear subframe retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar U-bracket bolts and replacestabilizer bar brackets and/or front stabilizer bar as required. Discard lower suspension arm stabilizer bar insulator (5493) and bolts.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar insulator installation position.
  1. Lubricate inside diameter of new lower suspension arm stabilizer bar insulator with Rubber Suspension Insulator Lube E25Y-19553-A or equivalent meeting Ford specification ESF-M99B112-A. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber lower suspension arm stabilizer bar insulators.
  1. Install new lower suspension arm stabilizer bar insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on front sub-frames and install new bolts. Tighten to 30-40 Nm (22-29 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Position steering gear onto front sub-frame and install retaining nuts. Tighten to 115-135 Nm (85-99 lb-ft).
    Install stabilizer bar link to front shock absorber and to front stabilizer bar, making sure that the stabilizer bar link is properly positioned. The letters "Top LH" and "Top RH" are moulded into the stabilizer bar link for correct assembly to the front shock absorber strut.
  1. Install new nuts and secure stabilizer bar link assembly to front stabilizer bar and front shock absorber. Tighten to 77-103 Nm (57-75 lb-ft) at front shock absorber strut and 47-63 Nm (35-46 lb-ft) at front stabilizer bar.
  1. Remove safety stands.
  1. Lower vehicle.
Apr 11, 2009 | 1995 Ford Taurus
Stabilizer bar
Howdy, sway bar/stabilizer. disconnect neg battery cable, disable air bag (if equipped, it was an option in 91), jack up vehicle, support w/ safety stands, remove front wheels, disconnect sway bar ends from the lower control arms, remove bolts retaining sway bar bushing brackets.remove sway bar. Check bushings for splits and deformation, clean inner and outer surfaces of bushings before installation, Make sure bushings are properly seated in their brackets. Tighten brackets to 12 ft lbs, and end mounts or link bolts to 16 ft lbs. Let me know how u make out countrycurt0
Oct 02, 2008 | 1991 Honda Prelude
Maytag Neptune MAH5500B Front Load Washer Logo
202 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
