Question about Audiovox Crane Plumbing Molded-Stone Double-Bowl Laundry Tub, White #FLTD11
How to repair a leek in a laundry tub - Audiovox Crane Plumbing Molded-Stone Double-Bowl Laundry Tub, White #FLTD11
  • 32 Answers
I have repaired this style sink with silacone then pained with garage floor paint
Posted on Dec 10, 2010
Door seal leeks. The rubber around the door leeks
Sounds like your bellows is worn and has begun to leak. Here's the way to change it...
The bellows will have a retaining wire on both the front panel and plastic tub interfaces. You need to remove the front panel wire first. Simply pull the lip forward until you can see the wire. Use a pliers or screwdriver to remove it. Peel the bellows off of the front panel and you can see the attachment to the tub. Same removal technique.
Be very careful when installing the new bellows to be sure it is seated fully and correctly all the way around the tub. Reinstall the retaining wire. Same installation technique for the front panel.
Good luck.
Jan 20, 2011 | Whirlpool AWM6120 Front Load Washer
Tip
HOW TO CLEAN A WASHING MACHINE
Washing Machines Need Cleaning, Too We interrupt this scintillating mechanical exploration of washing machine mechanics to bring up a very important matter: why your laundry might stink even after a fresh wash. It may be that your washer is dirty.
Regularly clean the top and door of the washer to prevent the buildup of dirt and detergent. When you wash very linty materials, pull lint from the tub after removing the laundry. Built up lint can keep water and detergent from properly circulating and soap deposits themselves may cause laundry to smell bad.
To solve this problem, fill the tub with water and add 1/2 cup of baking soda or 3 cups of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach.
A word of caution: Rinse the tub thoroughly before wiping it out with bleach. The combination of ammonia and bleach forms a potentially dangerous gas called chloramine. This compound can cause health issues ranging from mild skin irritation to digestive and kidney problems
Finally, run the machine through a complete wash cycle before you put any more laundry in. Hopefully, you were able to address your issue with these simple steps.
on Nov 03, 2011 | Washing Machines
Tip
The washing machine is draining but the water is coming back inside?
Check out this possibilities for water not draining in the washing machine: This problem relates to the hose connected to drain pump. The drain hose should not be in laundry tub more then 4 to 5 inches. Measure it and if it’s more then 4 to 5 inch then cut the excess hose in the tub. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly. But if the drain pump hoses are ok checked then this problem relates to slow drain of water from laundry tub. You can solve this issue by cleaning the drain pump blockages and dirt build up this will make the flow of water proper in the draining of the laundry tub.
This will help.thanks.
on Mar 18, 2010 | Washing Machines
Started normal cycle then gets to drain and spin clothes are still wet
Hello there:
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt, a worn clutch , or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. then retry ok
Oct 07, 2010 | Whirlpool Washing Machines
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
Tip
How to clean a wash machine
Regularly clean the top and door of the washer to prevent the buildup of dirt and detergent. When you wash very linty materials, remove lint from the tub after removing the laundry. Soap deposits may cause laundry to smell bad. To solve this problem, fill the tub with water and add 1 pound of water softener or 1 gallon of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach. Caution: Rinse the tub thoroughly before wiping it out with bleach. Ammonia and bleach can combine to form a very dangerous gas.
on Jan 16, 2010 | Washing Machines
I just did a load of laundry at my mom's beach house. Second load so far is fine, however, first load seemed to leek from underneath. All water/drainage connections were dry. We moved and cleaned area and...
If all connections were dry, the water may have overflowed the top of the tub during a spin /rinse cycle. That could happen if there was a lot of water (i.e. set for large load) and a small amount of clothes.
Jul 08, 2009 | Washing Machines
Leaking water
Does not sound like a bearing problem. Check to see if water is overflowing the top of the tub during spin cycle (due to spin action) and running down the side of the tub.  Water rising up the side of the tub during spin cycle could also be squirting up through bleach dispenser opening and running down side of tub.
May 30, 2009 | Washing Machines
Water leeks onto floor occasionally.
hello.
Welcome to Fixya.
  • nspect the water supply connections.
  • Inspect the drain hose.
  • Inspect the water pump.
  • Inspect outer tub for cracks or corrosion.
  • Inspect the tub seal.
  • Inspect the tub bearing.
Good Luck.
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Discharge hose does not fit onto laundry tub causing flooding.
Yes - they are sold at any hardware or appliance store. It is a drain tub clip.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 15, 2009 | Washing Machines
Audiovox Crane Plumbing Molded-Stone Double-Bowl Laundry Tub, White #FLTD11 Logo
35 people viewed this question
Top Audiovox Home Experts
john h
Tom Chichester
Are you an Audiovox Home Expert? Answer questions, earn points and help others
