Question about ACP Cavalry (CAUE37500) 500 GB USB 2.0 Hard Drive
I'm back OK, I'm back
  • Lee A.
    Lee A. May 11, 2010
    Thank you. I hope once we work this out you might still be able to rate our chat as helpful or better. Now you said you needed to recover the data is that correct?
    Thanks,
    Lee
  • 4,472 Answers
What is the exact error you are receiving again? I want to make sure to provide you the most accurate support.
Lee
Posted on Jun 18, 2008
I have 03 dodge durango back up lights dont work
use a test light to check each side of the fuse must be battery voltage both sides of fuse, if ok with the transmission in reverse and key on check for battery voltage each side of the back up switch located on the gear box, if ok check for battery voltage at the back up light if ok check the light has a good earth and the bulbs are ok.
Mar 14, 2016 | 2003 Dodge Durango
0xc18a0001 failure
You could try a power reset of the printer.
Press ON button to turn off printer
Unplug the power cord from the back of the printer
Remove all of the ink cartridges
Wait 3 minutes
Plug the power cord back into the printer
Press the ON button to turn on the printer
Install back all of the cartridges
If this does not work, you could try a hardware reset.
1) Press and hold LEFT ARROW and then press SETUP
Release both buttons
2) Press OK
3) Press & release RIGHT ARROW until LCD reads System Configuration Menu 2
4) Press OK
5) LCD reads Hardware Failure Status: Clear, Press OK to clear
6) Press OK, LCD now reads Cleared, Press Cancel to continue.
7) Press & release CANCEL until the Welcome or Ink System
Failure screen appears on LCD
8) DO NOT PRINT AT THIS STAGE
9) Use POWER button to turn OFF printer
10) Unplug power cord from electrical outlet and from back of printer
11) Wait 1 minute. plug power cord back into outlet first then back into the printer
12)Turn on the printer, Press OK
The printer will start to initiate, do not interrupt.
Dec 31, 2013 | HP Photosmart C6180 All-In-One InkJet...
They are probably in a format that the pda can not handle.
Sep 14, 2009 | Palm Tungsten E2 Handheld
Debroke in half need to turn transmitters back
Press menu, down down, up, ok, up up, ok, then press ok again to turn them on that will work if its on high contrast if it is on one of the others press press menu, right right, up, ok, up up, ok, then press ok again to turn them on. Hope this helps!
Jul 23, 2009 | Motorola Mobility i880 Cellular Phone
Is there a way to "reset" the memory
This is the total reset process step by step i found it on
www.avicx1forums.com and it worked fine.
REMOVE DISK
HOLD RESET AND EJECT
RELEASE RESET BUT HOLD EJECT
SCREEN WILL GO BACK IN AND OUT-THEN SAYS PLEASE PRESS THE RESET BUTTON…DON’T
THEN WITH JOY PAD PRESS …
UP,RIGHT,UP,RIGHT,DOWN,RIGHT,DOWN,RIGHT…THEN OK (JOYPAD BUTTON INWARDS)
PASSWORD SCREEN WILL COME ON SCREEN BREIFLY
TEST MODE SCREEN APEARS-CLICK JOYSTICK TO RIGHT ONCE
SCROLL DOWN TO NUMBER 6-PROGRAM FORCED WRITE (OK)
FIND NUMBER 1 SYSTEM PROGRAM (INSERT DISK --CNDV 40/50/60?)
PRESS 1 SYSTEM PROGRAM (OK)
SELECT 2 DVD/CD ROM (OK)
SELECT LANGUAGE… (ENGLISH)
PRESS (VIEW –POS) BUTTON
SHOULD SEE SYSTEM PROGRAM GOING UP IN %
WHEN FINISHED PRESS (BACK)
FIND NUMBER 6 PROGRAM FORCED WRITE AGAIN (OK)
NUMBER 3 APPLICATION PROGRAM (OK)
SELECT 1 UK ENGLISH...THEN PRESS (VIEW – POS) BUTTON
SHOULD SEE SYSTEM GOING UP IN %
TEST MODE PAGE 1
SELECT 6 - CLEAR BACK UP MEMORY (OK)
SHOULD SAY FINISHED THEN ASKS FOR RESET BUTTON TO BE PRESSED
PRESS RESET ON FRONT OF UNIT
START SAT NAV AGAIN
ASKES FOR LANGUAGE PRESS NO (READ TEXT)
SYSTEM STARTS
BUTTONS
OK = JOYPAD INWARD
BACK = JOYPAD TO THE LEFT…NOTE THIS WILL BRING YOU BACK TO PREVIOUS PAGE
BACK = BAND BUTTON ….NOTE THIS WILL TAKE YOU BACK TO THE MAIN MENU
May 09, 2008 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
Howto go back to Interlace mode
ok what u do is use coumpount caBLE OUT FROM DVD TO TV to see the pic back ok its going out the red green blue cable outs what happend when u did this ok try unpluging it for wile then back it may reset it if not take to store best buy they will hook it up to coummpunt cables then switch that output back to interlace ok thx nick
Feb 06, 2008 | Yamakawa DVR-628 DVD Recorder
Directions are off and the alert comes too late
REMOVE DISK
TEST MODE PAGE 1
START SAT NAV AGAIN
SYSTEM STARTS
BUTTONS
OK = JOYPAD INWARD
Aug 28, 2007 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
Treo 650 Hotsync Problem
Many factors can influence the synchronization process. you will have to go step by step from this: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(25004) Good luck.
Jan 04, 2006 | Palm Treo 650 Handheld
Prob with hot sync
You have to do a clean sweep of office.
Sep 12, 2005 | Palm Treo 650 Handheld
650 stopped syncing after I set up the email function
Reinstall software. If this is helpful, please post as such. TY
ACP Cavalry (CAUE37500) 500 GB USB 2.0 Hard Drive Logo
43 people viewed this question
Top ACP Computers & Internet Experts
David Payne
David Payne
Are you an ACP Computer and Internet Expert? Answer questions, earn points and help others
