Question about GE Spacemaker GSM1860NSS Dishwasher
The soap dispenser on my GE diswasher, model # GSM1860NSS does not seem to open at the correct time during the washing cycle.
5 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
  • 3 Answers
SOURCE: Soap dispenser does not open during cycle
Had similar problem. Water was not hot enough. Check your manual for proper water temp.
Posted on May 30, 2009
  • 2976 Answers
SOURCE: Soap dispenser door not opening up
If the soap door doesn't open all the time, remove the outer door cover and remove any obstructions. There are pieces of styrofoam and cardboard inside the door that come loose from time to time, and prevent the linkage from operating freely. They can be re-glued OR eliminated.
Posted on Oct 18, 2009
  • 189 Answers
SOURCE: Soap dispenser won't open on old GE diswasher
Hello-  These dispensers are mechanically linked to the timer and can get jammed or fail over time.  If you feel confident of your skills, you might try turning off power and taking door panel off to check these linkages.  With luck it will just need to be freed up to operate.  If not, parts are still available.  Just a spring and a couple of plastic levers involved.  Let me know if this info is helpful.  Have more if needed.. Please acknowledge this post.  Thanks-  Ed
Posted on Mar 27, 2010
The water isn't getting hot
If the water to your kitchen tap is above 120 to around 145 your machine is getting hot water. If not your need to adjust your hot water heater.
It is fine to open the DW door during the wash cycle. The unit will hold the wash cycle. Open the door during the start of the wash cycle (not rinse) and see it the dispenser door is open. If not it could be the timer is not sending the proper signal to the dispenser on when to open. This would be a timer issue and you would want to replace the timer. I doubt that this is it but it is possible.
Hope this helps.
Mar 22, 2010 | GE Dishwashers
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
My soap dispensar inside does not open during wash
its just a bad (failed ) dispenser. replace it . this should correct problem . mm
Dec 07, 2009 | Washing Machines
Cleaning Cycle not Starting
Please provide the model number and the approximate age of the dishwasher.
If this diswasher uses a turning dial to select the cycle, which turns as the dishwasher progresses, I strongly suspect that this timer has failed and needs replacement. Especially since the soap door never opens. Does the dishwasher drain during and at the end of the full cycle?
Mar 29, 2009 | GE Dishwashers
Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Dec 24, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
GE Spacemaker GSM1860NSS Dishwasher Logo
52 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
