Question about Lectrosonics FENDER PASSPORT PD-150 + 1 SHURE HANDHELD&1 LAVALIER WIRELESS SYSTEM / Microphone
I have a Fender Passport 150 and my microphone is won't work but everything else does......????? Thanx Mike
    Scholar:
    New Friend:
  • 101 Answers
Mike try the microphone if possible on another set If the mike makes a noise check for frayed and bad cables. As far as I know the mike is a dynamic mike and connect it to the speaker of a small transistor radio and it should sound.like a small speaker for dynamic mikes and ordinary speakers work just the one as a generating device(Speaker) and the other as a sound pick up Look at small to way radio's the send is the speaker a mike and on receive it is a speaker, Hope this help
Posted on Sep 20, 2014
5 Suggested Answers
  • 1138 Answers
SOURCE: how do i get a manual for the fender passport
Try here:http://www.fender.com/support/manuals/pdfs/manuals_elec/fenderaudio/PassportP150.pdf
Posted on Oct 17, 2009
  • 140 Answers
SOURCE: When the the Fender Passport 250 is plugged into
If there is a 120hz buzz then there is a ground loop between the computer and the passport. You need to get a ground isolator to go between the two. If the buzz is deeper the may be a audio ground off or the hum is comming from the power supply
Posted on Jan 05, 2010
robotek
  • 1512 Answers
SOURCE: woffer wont work
If you have tweeter drivers working in your speakers, this is a good sign that the amp is still working. If there is no sound at all from the woofers, then it is most likely that the woofers have failed.
To determine this, if you are good with a screwdriver, and have a multimeter, you could dismantle the speaker enclosure and check the voice coil of the woofer. Use the low ohms range to check to see if the woofers have gone open circuit. If they have, then replacements would be needed. It is also probably a good idea to work out what was happening prior to the speakers failing. They should not generally fail unless subjected to extreme levels of distortion. If the unit is still under warranty, you should take it to an authorised dealer. OR if it is not under warranty, and you determine that the woofers have failed, you can go here to find an agent to source the replacement parts, or repair the unit for you. For a dealer near to you, CLICK HERE
If you are not in the USA, let me know and I will assist you to find someone in your country.
Happy to answer any questions that you may have, and please dont for get to rate my solution. Cheers
regards robotek
Posted on Apr 20, 2010
  • 5603 Answers
SOURCE: can I place my Fender Passport P-150 SPEAKERS ONLY
The speakers are 8 ohm (three 2 ohm in series in each cabinet).
You can connect them in parallel with others HOWEVER you cannot go below 4 ohms a side with your amp. This means you could use ONE other 8 ohm speaker in parallel with one of the passport speakers PER side.
Since the amp can vastly exceed the passport speaker rating you need to be careful to not overpower the passport speakers. One way to HELP regulate the level to the passport speakers is to use a LONG small gauge speaker cable on the passport speakers. Use a 50 foot 16 gauge speaker cable while using heavier, shorter cables on your mains.
With your Samson I would use mains rated at 300 Watts CONTINUOUS power, or at least maintain discipline in volume level to [revent speaker damage.
ALWAYS loop your speaker cables through handles of the enclosure to prevent them being pulled out during use which will destroy your amp... VERIFY the plugs are seated before pwering the system.
Posted on Jul 08, 2010
I just bought a fender passport 150 and it isn't very loud and the channel lights aren't even coming on when I plug in my guitar or my mic. You can hear the guitar and mic but only when the volume...
Turn down the VIP knob and try it. This is on channel 1 for announcement voice overs overriding everything. It has a threshhold setting for adjusting that. Here is the manual for it.
http://support.fender.com/manuals/pro_audio/Passport_P150_manual.pdf
Jun 05, 2011 | Fender Passport 150 Pro 150-Watt Class-D...
Can I place my Fender Passport P-150 SPEAKERS ONLY on another system as ''extra speakers'' to a larger system. The larger system is a Samson XM910 900 Watt.
Jul 08, 2010 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Woffer wont work in fender passport pd 150 tweeters work fine
regards robotek
Apr 19, 2010 | Lectrosonics FENDER PASSPORT PD-150 + 1...
I need to purchase a lavaliere type mic for my passport 150 and I am not sure what I need, It comes with a hand held ireless mic but I want to use a lapel type.
Wireless systems can be purchased as either lapel or handheld systems. Talk to the dealer that you are purchasing the wireless from and let them know you want a handheld system.
Apr 13, 2010 | Lectrosonics FENDER PASSPORT PD-150 + 1...
I would like to hook up my boss br 900 cd and a digitech vocalist 2 to my fender passport 250 could you please help me. Emery
1st connect the digitech vogalist
(Line Out L/R)
output to one (line input) from boss br 900 and the boss (line output) to the passport (stereo input) use a high quality cables, to supress noise efect, on output.
Jan 08, 2010 | Fender Passport P-10 Professional...
Fender Passport 250:
The manual is here if you don't have one:http://www.fender.com/support/manuals/pdfs/manuals_elec/fenderaudio/PassportP250.pdf Have a look at page 9 and read the VIP Channel 1 only section. It will explain the solution to your problem and the settings to overcome it. Please let me know if this helps.
Nov 29, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
How do i get a manual for the fender passport p-150?
Oct 12, 2009 | Fender Passport P-10 Professional...
How do I open a fender passport 150 speaker cabinet?
There are screws running down the sides of the front panel which you will have to remove. The circuit board is secured to the front panel by the nuts, washers etc. that the controls and jacks are fastened with. Once you get the panel; loose gently move it forward so you can see any connections to the circuit board. Make careful note of all of these and draw diagrams. You will have to completely remove the panel from the enclosure and then the circuit board from the panel. The jack in question will be mounted on the circuit board and soldered to it on the reverse side. You will need to unsolder it, obtain an exact replacement, solder in the replacement and replace the board on the panel and the panel back in the enclosure. Make sure everything is connected exactly the way it was originally. Hope this helps.
May 23, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Fender Passport makes loud chirpping knocking sound after on for only 5 10 minutes
I have one that is doing the exact same thing. It's at a Fender
Authorized Service Center now. Hopefully dude can find the
problem. Fender says there is a 5 year warranty on it, so I
expect them to make good on their promise. Did you get
yours fixed?
Mar 11, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Fender Passport P-250
If you're still in need of a manual for your Fender Passport P-250 it can be found at:
Sep 27, 2008 | Fender Passport P-51 Consumer Microphone
256 people viewed this question
Top Lectrosonics Audio Players & Recorders Experts
Michial Gueffroy
Karl Luedemann
Gerhardus Stroebel
Are you a Lectrosonics Audio Player and Recorder Expert? Answer questions, earn points and help others
