Question about Garden
My husband had to trim an interior door for a bedroom, our house is older and none of the sizes they sell at home depot would fit right, it cracked at the bottom of the door, where the inside meets the decorative outside, can we use wood glue to glue it back together? There is no damage on the outside of door at all, just at bottom.
    Problem Solver:
  • 6 Answers
YES YOU CAN,JUST MAKE SURE THAT YOU USE A GOOD BRAND OF GLUE AND THAT IT IS 100% WATER PFOOF OR IT WILL DISINTERGRATE AFTER TIME IF IT GETS WET. MAKE SURE YOU GET THE GLUE WELL IN THE CRACK,DON'T BE AFRAID TO USE A GOOD AMOUNT,THEN SAND ANY OOZING WHEN DRY.
Posted on Nov 14, 2010
Nokia 2600c-02 insert sim card
I had that problem with transferring my sim card into my new phone too. It's hard to believe (I know!) but not all sim cards are cut to exactly the right size to fit all phones. My husband got mine to fit by carefully shaving or trimming less than 1/8" off around all the edges of the sim card and then it fit just fine :) Please be assured that this trimming does not interfere with the embedded chip at all.
May 24, 2014 | Nokia 1661 Cell Phone
Tip
How to raise the value of a home with a basement by a good percentage
If you are trying to sell a house with a basement and want to include rooms in the basement in the advertising their must be a way to exit the house from the basement. for a few thousand dollars now you can add the rooms and raise the value significantly. Egressed windows are windows in a basement large enough to qualify as an exit. You will have to call a concrete cutting contractor and have him cut out the window size. then install the window. now instead of your add saying a 2 bedroom, 2 bathroom house with a basement. You can say a 2 leve, 4 bedroom, 2 bathroom house!
on Mar 19, 2011 | Tools & Hardware - Others
Making a shimm for a guitar
depending on what you are shimming here are a few options. 1. home depot or lowes actually sell different sized shems according to there thickness just ask someone in lumber and they should be able to direct you to them. 2. your guitar picks come in all different thickness's so you can cut and trim them to the size you need to shim whatever your working on.
Jan 09, 2013 | Ibanez Music
We have an older model Lennox ac model #HS26-461-P and we are trying to find out what the tonnage is. Can you tell me where to look or if you know what it is will you please tell me?
The answer that (TheMobilian) left couldn't be further from the truth, of offense. So you're saying if you have a 1000 sq ft house with 4 bedrooms you'd have 4.5 tons of cooling? That's insane, the compressor in that system would be shot in about 6 months from short cycling. Their are many factors in sizing equipment, but none of them involve how many bedrooms you have. If you don't know how to calculate load from windows and insulation factor, then you can use the old (1 ton per 500-550 sq ft) that will get you close.
Jun 18, 2010 | Heating & Cooling
How to remove front dopr panel on 1995 Lincoln Town Car
Front Door Panel - Town Car - Removal
CAUTION: To avoid breakage of door pull cover(s), insert a screwdriver diagonally between pull strap and chrome bracket. Snap out both sides then remove.
Snap out two door pull strap retaining screw covers. Remove screws.
Remove two screws on front and rear side of front door trim panel.
The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
NOTE: Do not use front door trim panel (23942) to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
Remove window regulator control switch housing from back of front door trim panel . Lift up housing, remove retaining screws and disconnect all connectors.
Disconnect driver seat regulator control processor switch (driver door only) if equipped.
Twist out interior lamp wire assembly and remove the front door trim panel.
Installation
Ensure plastic watershield is secured to door panel.
Position front door trim panel to door. Connect interior lamp wiring.
Position the window regulator control switch housing and connect switch connectors. Install the retaining screws.
Connect driver seat regulator control processor (14C708) (driver door only) if equipped.
Align door lock side to its mating slide on the sheet metal (front doors only).
Snap in front door trim panel. Ensure all retainers fit properly.
Install two retaining screws on front and rear side of front door trim panel .
Install two retaining screws and pull strap covers.
Good luck Remember rated this).
May 31, 2010 | Lincoln Town Car Cars & Trucks
I need extra keys for my Kwikset handleset. Had new keys cut at 2 different stores and none of them work. The keys fit in the lock, but won't turn either way. Original key turns very smoothly.
The problem you are having has nothing to do with your lock. Modern key cutting machines are so automated that they do a very poor job in key duplication. I suggest that you find an old hardware store that has an older key machine. Or possibly, it might be cheaper to simply replace the lock set. A new Kwikset keyed entry sells for about $40.00 for a lever handle. Remember to have extra keys cut at the store when you purchase the lock...so you can check the duplicates in the store. I do this at Home Depot regularly. They have a new machine, but with the lock right there, they can manage to cut some duplicates after a few bad ones.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 24, 2009 | Locks & Locksmithing
My sons door jam is cracked down the middle. How can I repair
if this is for a house interior or exterior door you need to remove the jamb and replace with a jamb from home depot or lowes measure the jamb and they have replacement kits
Aug 27, 2009 | Hardware & Accessories
Need to find a way to take off the drivers side window motor
Motor
  1. Disconnect the negative battery cable.
  2. Remove the door trim panel and watershield.
  3. Detach the motor wires at the multiple connector.
  4. Remove the motor retaining screws using Torx® drive bit set D79P–2100–T or equivalent, and separate the motor from the bracket and cable drum housing.
  5. Remove the motor from inside the door.
To install:
  1. Position the motor and drive to the cable drum housing and motor mounting bracket. Install the 3 motor screws and tighten.
  2. Connect the power window motor wiring.
  3. Connect the negative battery cable.
  4. Check window operation.
  5. Install the watershield and door trim panel.
Door Panel
  2. Snap out the two door pull strap retaining screw covers. Remove the screws.
CAUTION To avoid breakage of the door pull covers, insert a small screwdriver diagonally between the pull strap and chrome bracket. Snap out both sides then remove.
  1. Remove the two screws on the front and rear side of the front door trim panel.
  2. Using the trim pad removing tool, pry the trim panel retaining clips from the door inner panel.
NOTE Do not use the front door trim panel to remove the trim clips from the door inner panel. Replace any bent, damaged or missing push pins.
  1. Remove the window regulator switch housing from the back of the front door trim panel. Lift up the housing and disconnect all connectors from the switch housing.
  2. Disconnect the driver seat regulator control processor switch if equipped.
  3. Twist out the interior lamp wire assembly.
To install:
  1. Ensure that the plastic watershield is secured to the door .
  2. Position the front door trim panel to the door. Connect the interior lamp wiring.
  3. Align door lock side to its mating slide on the sheet metal.
  4. Snap in the front door trim panel. Ensure all retainers fit properly. Install the two retaining screws on the front and rear side of the front door trim panel.
  5. Connect the driver seat regulator control processor, if equipped.
  6. Position the window regulator control switch housing and connect the switch connectors. Install it to the front door trim panel by snapping it in, or by installing the screw at the rear.
  7. Install the two retaining screws and pull strap covers.
  8. Connect the negative battery cable.
Aug 27, 2009 | 2000 Lincoln Town Car
Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Mar 31, 2009 | Hampton Bay 04345 Cruiser Ceiling Fan
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
