Question about Dell Computers & Internet
When turn on comp the start screen is black and cant read the writing
  • 2,229 Answers
I'll have to assume that the computer is actually starting. If this is so, then the fact that you can't really see the writing on the screen means that the fluorescent backlight has burned out. If you can't adjust the brightness, then this is the most likely problem. var fctb_tool=null; function FCTB_Init_1468f5205a78487fa26d4d548eda01b4(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_354835c647de45ffbb4b3d77c8253e06(t) { fctb_tool=t; start(fctb_tool); }
Posted on Nov 14, 2010
HOW TO TEST A COMPRESSOR
This is a bit complicated. Turn off power by unplugging it or turn off breaker/disconnect. On the comp you have 3 terminals, C, S, R. (Common start and run). You need to mark, label, or write down what wire goes to what terminal(red to run, black to common.....ect. Remove all 3 wires from the comp. Using a volt/ohm meter set to the ohms position, measure the resistance between common & start, common & run, run & start or C to S, C to R, R to S. All three readings should give a different reading. If all terminals are equal readings or if any terminal shows open or (infinite resistance) then the comp is damaged. Also test each terminal to ground by touching 1 lead to 1 terminal and the other lead to metal housing of unit ensuring you are touching metal and not paint. If any terminal shows a reading, other than infinite, to ground then the compressor is damaged.
Jun 01, 2015 | GE Zoneline In Wall Ptac Unit Air...
Dll error
Try a system restore and bring computer back in time before this occured.
May 01, 2012 | IBM Thinkpad T43/p Notebook
DOES NOT START SHOWS BLACK SCREEN
do a power drain
- shut down the comp, unplug the adaptor and unplug the battery
press and hold the power button without any power connected to the comp
- plug the battery and plug the ac adaptor and turn on the comp
Oct 04, 2009 | HP Compaq nc6220 Notebook
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
Cant read previous content..
i can assume you burned the latest in windows vista, as it is in a different format than XP, you may need to install nero incd on the pc that you need to view the contents, you can try it here
http://www.nero.com/eng/nero8-introduction.html?NeroSID=33e9b31d712a4460409b722992715ece
Aug 16, 2008 | Dell (0R708) CD-RW/DVD-ROM (Combo) Burner
Sony viao, comp. boots up. screen very dark.
Is the screen just dark s that you can barely see what's on it, or is it completely blacked out?
Jul 27, 2008 | Dell Latitude C610 Notebook
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
