Question about Western Digital (WD3200JS) 320 GB Hard Drive
Jumper settings for slave 250 gig hd wd2500js
ariscanete
  • 5 Answers
SOURCE: New Hd HELP
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...http://www.wdc.com
Posted on Apr 09, 2007
Beni S-P
  • 1006 Answers
SOURCE: jumper settings
Here you have MANUAL'S
Posted on Mar 24, 2008
  • 46 Answers
SOURCE: how to tell which jumper is master and which is slave
normally most harddrives are the same, copy the other one see if that works.
Posted on Mar 28, 2008
Kidyubyub
  • 143 Answers
SOURCE: Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Posted on May 18, 2008
SOURCE: I have a quantum fireball 20.4 gig drive where do the jumpers
There is normally a sticker on the drive, which indictates the settings.
Posted on Jan 04, 2009
Putting this drive in a dell, I,m Not familiar With the Jumper settings,SSC,PM2, Opt 1, opt2, i,m use to CS, Slave,Master ETC
http://wdc.custhelp.com/app/answers/detail/a_id/1400#jumper
http://www.overclock.net/faqs/99291-info-what-ssc-jumper-my-hard.html
Jun 09, 2011 | Western Digital WD2500JS 250GB SATA2...
My WDC WD2500JS hard druive is getting noisy and slow. I am thinking of replaceing it before it dies and at the same time do a clean install of Win7. It is now XP. Can I make this drive a slave until I...
first up
uninstall a few unnecessary programs
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
second
yes you can make it a slave
you will have to change the setting in BIOS for master/slave aswell as the jumper settings
during the boot up process you will see on the screen for a short time press a certain key to enter set up press that key to enter set up
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
make sure the computers motherboard will support windows 7
wait until you get the new drive before before connecting your hard drives to master/slave
depending on the amount of drives your computer has you might have to change letters on all drives
naming of the hard drive you might be able to change the name opening windows explorer navigate to the drive then right click on the drive then select rename
Dec 15, 2010 | Western Digital 250GB WD RE SATAII...
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Want to make a slave drive
The WD2500JS drive is a SATA drive, these do not have Master/Slave settings each drive connects to its own port.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 24, 2010 | Western Digital Caviar SE WD2500JS...
Setint the jamper as a 2nd drive and Do i need to farmat it frist
If I recall right this HDD is a PATA (IDE) type. As for the Jumpers please check the following link. The jumper should be as Slave drive.
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
May 15, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Since putting an hitachi 250 gig hard drive in to my comp it is causing all sorts of probs! comp wont start up hangs. next time starts up perfectly and after a while in windows get get blue screen says...
okay could be you computer isnt set up properly for the HD
is this and internal HD or external??
your jumpers could be set wrong on the HD
you just dont put a HD into a computer without setting the jumpers properly
Jun 20, 2008 | Hitachi Computers & Internet
Hard drive instalation
To slave the Maxtor you remove the jumper or jumpers
Oct 30, 2007 | Maxtor Hard Drive
New Hd HELP
Apr 08, 2007 | Western Digital Caviar SE WD2500JS...
Western Digital (WD3200JS) 320 GB Hard Drive Logo
1,283 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
