Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman 19.5 hp lawn tractor model # 917.271825 and the engine idles up and down constantly I ahve changed the air and fuel filter but it still is doing it. What should i check?
  • 110 Answers
Carb is dirty and leaning out so the governor throttles the engine up & down causing a surge. You can try using a good quality fuel injector cleaner product mixed in the gas. That may help but if that doesn't work it will be best to replace the carb. That is an older engine and the carb is not likely fixable. It is a matter of how much money you want to throw at it. Putting a carb kit in it and giving it a through cleaning has no guarantees then you will still need to spend money on a new carb. The carb for that runs about $165. If you replace it yourself I'd recommend taking pictures as you take it apart so you can see where all the linkages go and you will be able to put it back together without problem. Hope this helps. Please vote yes if you find it helpful.
Posted on Nov 18, 2010
  • mblegg Feb 24, 2011
    I have the same mower , I put a carb rebuild kit on my carb for about $20.00 bought it at a local hardware store done the work myself it is fairly simple to do only thing to remember is to clean the carb thoroughly cleaning all port holes, on a scale of 1 to10 , 1 being the easiest Iwould rate this job a #3 Iran my mower all season last year with no problems whatsoever!!
I have a craftsman 17.5 hp tractor that will start but soon cuts off. I have replaced gas. battery fuel filter and spark plug. Also burning a lot of oil to me.Have replaced fuel lines also. Seems to not...
Could be a head gasket. I'd recommend a compression test or better yet a leak down test that will show where the leak is. Hope this helps. Please vote yes, thank you
Nov 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 18 HP tractor model 917.274400 will not run
Sounds like something is clogged. It may need a new air filter or the carburetor may need cleaning out. Also I would check your fuel, if it is over 30 days old I would replace it. It may be losing compression and either need a new head gasket or the head bolts tightened when it is hot.
Good day.
Oct 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman riding lawn mower conks out even after we have changed the air filter, deck belt and fuel filter -
clean the carb and make sure the fuel filter is not got something in it...or the fuel lines before it.
Aug 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Craftsman lawn tractor 21.5 hp, model no. 917.272463. The engine starts well, but while running it spits and sputters every second or so, whether at idle or at full throttle. I changed the fuel...
Try changing the its oil-seals. The problem lies there. It may be damaged or the oil-seals are now smaller than its is used to and it is because of the heat. The oil-seal are rounded things that are made of rubber.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
505 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
