Question about Intermatic EH40 - Electronic Water Heater Timer - NEMA 1 Indoor Steel Case
After working properly for 5 years my Intermatic eh40 stopped working. I had to by pass this unit and connect the power directly to the heater. Prior to bypassing the unit, I pressed the event button to by pass the settings but its still dead.
The EH40 has size A battery located below the control buttons.
Pull down carriage and replace battery.
There are two metal connectors on either side of battery ... these connectors are kind of hard to get lined up when putting carriage back >> be careful not to bend.
Posted on Nov 14, 2010
I have a timer that won't hold the program time set schedule? I have paid an electrician to come out and check to make sure i don't have any shorted out wires?? Electrician didn't find any...
Question posted under 120volt Intermatic Eh10 timer.
I do not have repairs for defective timer.
EH10 has 1 year limited warranty.
Located just below the digital display is compartment for AA battery.
Display is controlled by battery.
Replace battery, press and hold reset button for several seconds to reset timer, and try to program again.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#EH10
http://waterheatertimer.org/pdf/eh10-manual.pdf
EH10 and EH40 timers are susceptible to line noise.
If timer is connected to water heater, there is no line noise. And electrician tested for shorting wires.
But when timer is connected to fan, pump, or other type of load, then interference can be a problem.
Intermatic can provide a filter.
http://www.intermatic.com/customer%20service.aspx
Digital timers, digital water heaters, digital washer and dryer, digital water softener, digital treadmill, etc are increasingly common, yet are not protected from surge.
People protect computers and TVs, but forget other costly items.
EH10 can be affected by surge.
Install whole house surge protection:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
Aug 17, 2011 | Intermatic 7 Day Electronic Timer Eh10...
When power is applied load one reads o.k. load two reads zero why?
You posted under EH40 240Volt programmable timer.
If I understand correctly, you are testing the terminals when timer turns ON?
Test shows 120V between terminal 4 and ground wire.
Test shows 0 volts between terminal 6 and ground wire.
Solution:
Test terminal 3 to ground -and- test terminal 5 to ground and make sure each tests 120V.
Test terminal 3 to terminal 5 for 240V.
If terminals 3 and 5 test correctly, but terminal 6 never has power, then relay inside timer has gone bad.
Contact Intermatic about 1 year limited warranty
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Intermatic EH40 - Electronic Water Heater...
After 7 years working properly, the event button has stopped working. There is no way to start the load in manual, or to change the program... What can I do?
You posted under EH40 Intermatic programmable timer.
EH40 Manual:
http://waterheatertimer.org/pdf/eh40-manual.pdf
1) EH40 uses size A battery. Replace battery.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#Battery
2) Reset the timer: Press and hold reset button for several seconds
3) Contact Intermatic because they are aware of specific problems with specific timers
4) Other folk have reported EH40 and EH10 last about 3 years.
EH40 has 1 year limited warranty.
I test timers: 7 years is reasonable run for inexpensive electronic time switch.
5) For longer lasting timer, consider Next Generation: battery is replaced every 8 years
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Feb 28, 2011 | Intermatic EH40 - Electronic Water Heater...
Need diagram showing a/c power and switched termanels
You posted under EH40 Intermatic timer.
The EH40 has a 240V clock
The terminals are numbered 1 2 3 4 5 6
The 240Volt clock is terminal 1 and 2
The first HOT wire from breaker connects to terminal 1 and 3
The second Hot wire from breaker connects to terminals 2 and 5
The wires to Load connect to terminals 4 and 6
If you need more help, add a comment and I will help
Nov 01, 2010 | Intermatic EH40 Energy Controls -...
My EH40 is not supplying power to the water heater. I hooked the power line in to posts 1 and 2 and I hooked the load out to posts 4 and 6. When I use my power checker it reads no power to posts 3,4,5,...
I have an EH 40 sitting in front of me right now.
The link above shows correct 240V water heater timer wiring for EH40
Link below shows an overview picture of EH 40 connected to 240V water heater
http://waterheatertimer.org/images/EH40-water-heater-circuit-5.jpg
http://waterheatertimer.org/240-v-water-heater-circuit.html
EH40 has a 240V clock.
Terminals 1 and 2 send power to the 240V clock
Power to the clock terminals do not pass through timer to any other terminal
How to wire EH40 for 240V
240V line has 2 hot wires from breaker box.
Lets call these wires Hot1 and Hot2
These wire are interchangeable on 240V circuit
Hot1 connects to terminal 1 with a jumper to terminal 3 (or connect to 3 and jumper to 1)
Hot2 connects to terminal 2 with a jumper to terminal 5 (or connect to 5 and jumper to 2)
240V circuit has 2 wires going to the Load
Let's call these Load1 and Load2
These wires are interchangeable on 240V circuit
Load1 connects to terminal 4
Load2 connects to terminal 6
If the timer is still not working, go back to the breaker and test if it is delivering 240V to the circuit.
If breaker is bad on one leg, then the circuit can test with live power, but the 240V appliance will not work.
240V circuit requires both legs of 240V before circuit is complete.
Oct 24, 2010 | Intermatic EH40 - Electronic Water Heater...
How to wire an intermatic eh40 water heater timer in simple terms
Don't know how to get more simple then the wiring straight from Intermatic...
Here is the link to the manuals for your timer...
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
heatman101
Sep 18, 2010 | Intermatic EH40 - Electronic Water Heater...
After hooking up line wires to motor and load wires from water heater to load terminals,diasgram shows jumper wires from terminbal 1 to terminal 3 and terminbal 2 to tertmninal 5. voltage is 240.thank you ...
That is correct.
LINE 1 (incoming hot wire from source or circuit breaker) connects to terminal #1 then jumps over to terminal #3 using the _same_ gauge wire.
LINE 2 (other incoming hot wire from source or circuit breaker) connects to terminal #2 then jumps over to terminal #5.
The LOAD (outgoing to water heater) then connects to terminals 4 and 6.
Aug 09, 2010 | Intermatic EH40 - Electronic Water Heater...
How do I install a Intermatic Electronic water heater timer EH40
Here ya go, follow the directions.
http://lib.store.yahoo.net/lib/rewilliams/eh10.pdf
Jul 08, 2009 | Intermatic EH40 - Electronic Water Heater...
How do I wire the intermatic Eh40 hot water heater timer?
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/eh10%20-%20english.ashx
Page 7. crossing wires are not connected. connections made only at screws.
4 & 6 go to water heater.
3 & 5 connect to power
small jumper between 1 & 3
second small jumper between 2 & 5
Jun 27, 2009 | Intermatic Electrical Supplies
Note that the "IMPORTANT!" paper insert that came with my EH40 shows one small jumper between 1 & 5 and the second small jumper between 2 & 3 (and, of course, the jumpers aren't really long enough to reach from 1 to 5!). Jumping 1&3, 2&5 makes more sense and matches the labeling on the plastic insulator piece...
Jun 21, 2009 | Intermatic EH40 - Electronic Water Heater...
Intermatic EH40 - Electronic Water Heater Timer - NEMA 1 Indoor Steel Case Logo
281 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
