Question about Amana ARS266ZBS Side by Side Refrigerator
What causes the refrigerator and freezer to stop cooling when the motor can still be heard running
tborn6
  • 700 Answers
SOURCE: freezer and refrigerator not cooling. Makes a buzzing noise
hello sbarrry2 it sound like the motor that is running continously is the condenseer fan and the buzzing and then the click would be the compressor trying to start up and going off on overlaod. shut the unit off at the swiutch, let it cool down (3) hours possibly and then try to turn it back on. this should work. Thanks for using FixYA
Posted on Dec 26, 2008
tborn6
  • 700 Answers
SOURCE: Kenmore side by side refrigerator/freezer is not cooling
http://www.appliancerepair.net/apnet/frameset?
http://www.appliancerepair.net/apnet/refr/ch05.htm
try this site for the aanswers that you seek
Posted on Jan 23, 2009
wheelshot
  • 102 Answers
SOURCE: Amana refrigerator stopped cooling.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Posted on Apr 11, 2009
mgprice
  • 744 Answers
SOURCE: FREEZER RUNNING OK REFRIGERATOR NOT COOLING
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 14, 2009
rafaelrs38
  • 12 Answers
SOURCE: freezer and refrigerator stop cooling, back of
clean all the dust and form the gril on the back of your frig
Posted on Aug 10, 2009
My refrigerator is not keeping temp and there is a code on the water/ice machine reads S(or 5)y EF. What does this code indicate?
If I'm not mistaken EF error code stands for Evaporator Fan which is the fan motor in the back of the freezer section. That would explain the noise you heard. The fan could possibly be frozen or stuck or the motor actually went bad and needs replaced. Without that fan running you will get very little cooling.
Apr 15, 2015 | Refrigerators
What causes refrigerator to stop cooling, freezing
Defrost timing system may not be working right.
Mar 08, 2015 | Refrigerators
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
The motor on my frostfree fridge never stops running. Below the freezer isnt cooling. The freezer is cold but not freezing
Hi, seen this a few times when i did apartment maintenance,the most likely cause is a bad thermostat.
Mar 06, 2011 | Magic Chef CTB1722 Top Freezer...
My refrigerator keeps running inside the freezer part ice is forming.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | Maytag MSD2756G Side by Side Refrigerator
Fridge side stopped working. motor running freezer side ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 30, 2010 | Whirlpool GD2SHGX Refrigerator
Refrigerator stopped cooling but freezer is fine. what could cause this and will it be expensive to fix?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 16, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung RL36SBMS Bottom Freezer problem
LOW HUMMING NOISE COULD BE THE COMPRESSOR CHECK CAPACITOR
Aug 19, 2009 | Samsung RB1955VQ Bottom Freezer...
Amana ARS266ZBS Side by Side Refrigerator Logo
229 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
