Question about MSI 915GLM-V Motherboard
Hi there, I have a 915glm-v motherboard. The onboard video died and I purchased a GeForce FX5500 AGP card and placed it in the computer. I made sure it was securely connected. But I can't see anything on the screen when I start the computer up. I know that I'm supposed to disable the onboard video, but it's not working so I can't get into the BIOS. Is there another manual way on the motherboard that I can disable the onboard video so the computer boots up showing on the AGP card?
  • 33 Answers
SOURCE: MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
Posted on Feb 19, 2008
map9966
  • 2351 Answers
SOURCE: HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
Posted on May 31, 2008
whitebirch
  • 433 Answers
SOURCE: Enabling onboard video in ASUS A7V400-MX motherboard
When you mentioned heat problems, my first though was the processor. Is you computer just shutting down and the restart in a little while? Then I would lean towards the CPU.
If it is a problem with you video card your computer might not boot up at all. I like your thinking of an additional fan, I would think more along the lines of cooling the entire case, that way you get the hard drive, memory, video, and the processor. I would look for two 120 mm fans and do a push it in the front and blow it out the back.
Now back to your questions:
1. Any AGP video card will do, they are still around and not hard to get for a replacement. and again refer to my statement above for cooling.
Yes you can also install a video card using a PCI slot. You should select in the BIOS PCI instead of AGP.
The manufacturers of the video cards didn't put a fan on there for years and hey we have summer here too. Now with the bigger vid cards
with a gig of memory on them...I guess they really do need a fan.
I am a bit confused, when you say on board I think of no video card at all, not in an AGP nor PCI slot. They do come that way also- right on board.
And most of the time if you are not a serious gamer they are excellent for everyday use.
Well I hope this does it for you my friend,
good luck, stay cool. Please leave a rating,
thank you kindly
Posted on Apr 27, 2009
  • 15 Answers
SOURCE: MSI K9MM-V Motherboard No vidoe on screen when I try to boot
the only thing i can sugest is clear cmos by moving a jumper on your motherboard see manual or removing cmos battery from motherboard for a few miniutes then replace
Posted on Jul 30, 2009
parrotheadpc
  • 2600 Answers
SOURCE: I need to disable the onboard video by finding the
Go to the device manage and instead of disabling it, uninstall it. Then power down, move the cable to the pci port. reboot, when windows brings up the new hardware found, hit cancel until it disappears. Go back to device manager and if it has re-appeared uninstall it again and go about your business.
Posted on Sep 06, 2009
HP pavilion A750w starts up, but doesn't seem to go to POST, or at least there is no video once I turn on the machine. Used original, and newer monitors. Replaced onboard video with EVGA GEFORCE FX5500...
Hi there you need to make sure the monitor is properly connected and make sure you install the drivers for the new video card.If you still have the problem you should open the computer and check the memory by taking it out and put in into another memory slot on the motherboard.If you have more than one memory in the computer please take them out one at a time and restart the computer if that does not work you should replace them you new one that is compatible with your computer.
Jun 13, 2010 | HP Pavilion a705w PC Desktop
Geforce fx5500
No, it won't. HP's specifications page for the motherboard show it has a PCI-E slot for a video card, and the FX5500 is an AGP card. The connectors are different and you won't be able to install it. You'll need to shop for a PCI-E video card.
Mar 25, 2010 | Nvidia GeForce FX 5500 Video Card Graphic...
Will it work with Agpx4 motherboard ?
After looking at the motherboard and video card you specified,
Agpx4 Ga-7zx-h Motherboard
The video card requires a AGP 8x slot and the motherboard only supports a AGP 4x.
Feb 01, 2009 | Point of View GeForce FX5500, Graphic Card
Geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Nov 26, 2008 | Palit Microsystems GeForce FX5500, (256...
Nvida geforce fx5500 256 agp compatible with intel d865gbf ?
Yes, they should be compatible. The Intel d865gbf has an AGP port that supports AGP 4x/8x, and so does the FX5500. You should be fine.
Nov 05, 2008 | Nvidia GeForce FX 5500 Video Card Graphic...
Nvidia GeForce FX 5500 / 256MB... Problem
Hi jhacy, I went over all you're posted questions conserning this issue with the FX5500 video card. Please include the manufacture name of you're motherboard & its model number. It is possible the video card is bad (Even if it's new). There are settings in the motherboard bios that me need to be shut off if the motherboard has an integreated video card onboard. It's possible that the AGP slot on you're board is dirty & needs to be cleaned. Please list the name or name's of the games you have tried to run but freeze you're computer or crash you're system.
I will automatically recieve an email from fixya when you post the information I have asked for above. Untill than, take care!
Jun 01, 2008 | Nvidia GeForce FX 5500 Video Card Graphic...
Geforce fx5500
timber710,
Please remove the geforce fx5500 video card. Blow out the AGP slot with some canned air. Re-seat the video card & make sure you install it with even pressure (front to back) with slight rocking motion untill the card is completly seated. Try running the system again. ( I'm thinking the card was not completly seated).
If your system freezes again re-set your cmos / bios. In your user manual pg. 2.
Boot to the bios & re-setup all your settings. Save & exit.
If your PC still freezes, try another AGP card because the 5500 seem to be defective.
So hate giving out bad news........
Luck timber710
Mar 09, 2008 | Biostar M7VIT 800 (M7VIT8A02) Motherboard
Geforce FX5500 installed to P4M800-M7A motherboard
hi,
can you start the computer in safe mode (press F8 key) and install the latest nvidia driver available from www.nvidia.com
make sure your windows is updated as well.
Mar 08, 2008 | InnoVISION Multimedia Technologies GeForce...
GeForce FX 5500-picture flickers
assuming you have set your agp slot in the cmos settings to the primary graphics controller and already had the agp graphics slot driver installed for the motherboard, try using a driver from the nvidia web site if you are having trouble with the driver that came on the cd. Use the VGA onboard graphics if you have any or fit your old card and click on the link below for XP Drivers http://www.nvidia.com/object/winxp_2k_93.71.html If you still have problems then you will have to try an ATI graphics card as it just may not be compatable with your make of motherboard
May 08, 2007 | XFX GeForce FX 5200 Graphic Card
MSI 915GLM-V Motherboard Logo
69 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
