Question about Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer
Error message: No Paper--Load paper then press OK. But there is plenty of paper, properly loaded in front and back trays. Paper was removed and reloaded several times. Printer was shut off and power cord removed and restarted also several times.
SOURCE: Out of Paper. Load Paper Error
I have the same problem with a new psc 1610. The paper is not grabbed. Their might be a sticky spray for the rubber rollers to help? Handfeeding each page currently (sigh). All else works well though. good luck.
Posted on Jun 25, 2007
SOURCE: Will not print
Try to power down the printer (including unplugging it from the wall) then take out the paper trays. From there, reseat the tray guides (so pull them all the way in, then all the way out). From there replace the paper in the tray, and then re-align the guides to the paper. Plug it in, and then try a test print.
Posted on Apr 18, 2008
SOURCE: Paper Out message
Make sure that you are loading it in the back and not the front, I didn't figure this out until I looked at the manual. If you're used to HPs then you want to load in the front, but actually if you look behind the scan door, there is a black panel that you can open, and that's where you feed the paper. That thing in the front is actually where the paper comes out of. Go figure.
Posted on May 23, 2008
SOURCE: Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Posted on Sep 07, 2008
SOURCE: Canon MP600 paper wont feed- error message- HELP!
Right ... After 5 minutes of looking and fiddling I have found the solution!! press the button abover HOME and it should change the tray in which you are printing from :D
Problem solved
Posted on Feb 08, 2009
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
MP530 printer will not pick up paper from autoload tray. Error message says add paper and press ok
First, shut the machine off.
Unplug the power cord from the wall and let you printer just sit.
Next, pull the paper tray.
Now open all covers front and back and check for any pieces of paper that might be blocking the paper path.
Load the paper tray with about a half inch thick stack of paper.
Plug in the power cord and turn the power on and see if it won't work for you
Feb 11, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Using HP 1100d Office Inkjet printer. Can't get 'out of paper' light to turn off. I have added paper, pressed the reset button, but light stays on, and printer will not operate.
Please read over the following information and follow step by step.
Issue Either before or during a print job, the message ' Paper Jam ' appears on the product control panel display. The product does not output paper or complete the print job. Solution Follow these steps to resolve the issue. Step one: Remove any loose paper
  1. Remove any loose paper from the paper tray and output tray. CAUTION: Do not remove jammed paper at this stage.
  2. Press the Cancel/No button on the product control panel to clear the paper jam message.
  3. If the paper jam message cleared, try the print job again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step two: Clear the jam from the back of the printer
  1. Press the Power button (c01345237.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the rear access door: Turn the knob one-quarter turn to the left and pull the door away from the product. Figure 1: Remove the rear access door c01489996.gif
  4. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollers While the rear door is removed from the product and the power cord is disconnected, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear access door. Gently push the door toward the product, and then lock it in place by turning the knob one-quarter turn to the right or locked position.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
Step four: Reload paper and test the printer Load a stack of plain white paper in the paper tray and try the print job again.
  1. Press the Cancel/No button on the product control panel to clear the paper jam message.
  2. Lift the output tray.
  3. Pull out the front paper guide on the paper tray and slide the side paper guide as far to the left as it will go. Figure 3: Slide out paper guides c01489992.gif 1 - Front paper guide 2 - Side paper guide
  4. Load a stack of plain white paper, print-side down into the paper tray. Make sure the paper stack is no higher than the top of the front paper guide.
  5. Adjust the side and front paper guides to fit snugly against the paper stack. Figure 4: Adjust the side and front paper guides c01489993.gif
  6. Lower the output tray.
  7. Disengage the photo tray: On the output tray, pull the slider (visible through the output tray) away from the product until it stops. Figure 5: Disengage the photo tray c01489994.gif
  8. Try the print job again.
Step five: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. Have a good day,
Jun 18, 2009 | HP Inkjet 1100d Printer
Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
May 13, 2009 | Konica Minolta bizhub C250 All-In-One...
Cassette error
On the control panel for the printer, there's a Feed Switch button that's easily touched by accident. Ensure the Feed Switch is set to the paper source you're using (e.g. either the back or front). The graphic of the printer next to the Feed Switch button will light up to indicate the paper tray it's attempting to use.
Dec 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Paper Out message
May 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Logo
305 people viewed this question
old marine
old marine
