SOURCE: GE JVM1640 Spacemaker Microwave Oven over the stove
You don't. Get service for this. Incorrect installation is dangerous.
SOURCE: I have a Ge spacesaver
I assume you also have the wall mount plate with your oven.
That wall mount carries the bulk of the ovens weight and you normally do use the long screws to bring the front of the oven up to the bottom of the cabinet above the unit. Filler blocks made to fit and to the correct thickness ( to fill the gap between the bottom of the cabinet and the top of the oven) are usually made so that the oven 'nests' snuggly to the underside of that cabinet. Without templates to get holes properly lined up.. they aren't that easy to locate the clearance holes in that cabinet. You can get user manual and installation details at this GE website..
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
Hope this helps..
SOURCE: where is serial number located on GE Spacesaver?
If you open door and look at upper edge of cabinet it should be there.
SOURCE: Have a GE microwave spacesaver oven/Model
call a pro. these units run at a deadly high voltage. simply not worth your life!
SOURCE: WHat part number for this GW Microwave oven thermostat?
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
It will tell you where each one is located and what it's called, and should have the part numbers.
Three of them should read normally closed and one should read open.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
If you still need help, let us know.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
