Can't Connect I recently purchased a Edimax PS-1203, and connected it to my Negear DG834G ADSL router. Now, both lights, on the server itself and the number 4 light on the router (as that is the port it is connected to) light up. However, when i go into the "attached devices" menu on the router, it is bringing up everything but the print server. I installed the driver, etc, but that didn't help. Also, during installation, it brings up a window sayin to pick a print server, but the box is empty. Any advice will help. Thanks My Edimax PS 1206Mfg is doing the same thing. I can't find it on the network.
  • WCarbone Jun 19, 2008
    I recently purchased a Netgear WPN824. The Netgear WPN824 is connected to a Speedstream 5200 modem. Internet connectivity is fine. I have not enabled the wireless capabilities; everything is connected via ethernet. I have enabled DHCP and have three computers up and running. I can't get my HP JetDirect J6057A on the network. No IP address is being assigned. Did a cold reset. IP address reverts back to default Tried to install new firmware but device is not found on network. Ran configuration page from printer. "TCP/IP status is Ready. Default IP Configured Continuing to DHCP." Obviously, checked cables. Lights are on both ends of ethernet connection. The HP JetDirect played well with others with my old router.
  • WolfHai Aug 19, 2008
    Trying to install the Edimax print server 1206UWP. I connect all the cables, do the administration - setup (V. 3.8.42) and then it comes to: Searching Your Print Server. The result box comes up empty.
    I tried to set the local area connection IP address to different values (e.g., (supposedly the IP address of the print server is Same result.
I fixed my problem by resetting the print server. You have to hold in the reset button for at least 20 seconds for it to work. I was previously just pressing it without holding.
Hope that this may help someone else.
Regards Jackie Macmillan
Posted on Jun 19, 2008
How do I get my dsi connceted to the internet
The NetGear DG834G is an ADSL router. If you an ADSL internet connection, it should connect via PPPoE autentication.
This means that you must configure the username and password, on the router, provived by your internet service provider.
Please read the "Installing Your Router Using the Smart Wizard" section on the router's manual here and follow the steps.
Mar 12, 2011 | NetGear DG834G Router
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say to and default gateway as and on the router set the router's ip address to make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to - and default gateway or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
My Netgear adsl router is not getting connected to Internet in pppOe mode ..
POPE configuration is logs into your ADSL system and connects to your ISP provider server to link , so one of the reason why it dosent is due to either password and username not correct. Log unto IP address of your Router and go to WAN configuration , Check your username and password and reset to the initial password and username your ISP provider gave you , when you signed up with them. Then apply changes , off your router for 1 min and then power it , then wait for the ADSL light on the router to be stable , connect to the IP address of your router again and "Volla" , it should be fine , if not , contact your ISP provider....
Oct 07, 2010 | NetGear DG834G 802.11G Wireless ADSL...
Netgear DG834G wireless router wth built-in modem doesn't connect
Check if you have types all the configurations properly, namely Encapsulation / user name n password.
Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
Netgear wireless modem router dg834g i have no disc with router also im on cable moden how do i change it over
ok... you ned assistance... the modem connects to the router... if you look at the back of the router it should say internet. thats where you connect your modem to. then everything goes through your me and I will try and assist
Jun 21, 2009 | NetGear DG834G Router
No Ports available
The default IP in the D-Link router is 192.168.1.x
The default IP in the Edimax is
Your 3rd octet (the # after 168) has got to be the same for the two of them to communicate.
So, you can either reIP your router, or connect your PC to the print server and change it. The software for the print server should have a tool for finding the PS by MAC address, then you can go in and reset it to 192.168.1.x
Sep 17, 2008 | Edimax PS-1206U (PS1206U) Print Server
No access to internet via wireless or ethernet
Check ADSL is active and connectted on the router.
Use webmanagement link the link below.
username: admin
password: admin
If the above details does not allow you to connect, check under the router for correct details.
Mar 11, 2008 | NetGear DG834G 802.11G Wireless ADSL...
I cannot get connected to the internet.
If I understand you correctly you currently have a computer connected directly to your ADSL Internet connection and it can connect to the Internet. When you disconnect the computer, connect the DG834G router to the Internet connection and then connect the computer to the router you loose the Internet connection. It sounds like a ?simple? case of the router not being configured correctly. What I would suggest is to reset the router to its default configuration and follow the installation instructions again from the start. I?m not a big fan of the software configuration wizards that these home routers come with BUT they are the best way to easily configure the typical installation. To reset the router: in-between the 4 Ethernet LAN ports and the ADSL port there is a small reset button. Press and hold the reset button until the test LED turn on (about 10 seconds). Release the button and wait for the router to reboot. Let us know if this works or not. If you still have problems the more details and error messages you can supply the better.
Dec 29, 2006 | NetGear DG834G Router
Edimax PS 3100A+ IP reset
First you must connect to the printer using lpt port. then that server automatically printing its information about it. example: IP address and ...
Aug 08, 2006 | Edimax PS 3100A+ (PS-3100A) Print Server
Computers & Internet Logo
824 people viewed this question
David Payne
David Payne
