Question about Car Audio & Video
Main speakers dont work only tweeters do . bmw e38 99
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Posted on Apr 15, 2007
gopakumarg43
  • 74666 Answers
SOURCE: 2005 jaguar x-type,factory stereo wiring
Hello
Visit this site. You can get tie stereo wiring digram from here.
www.modifiedlife.com/2005-jaguar-x-type-car-stereo-wiring-diagram/Cached - Similar
Posted on Dec 19, 2011
Tweeters will not work
might be a problem with the crossovers inside the speaker box.take them to a technition
Nov 10, 2013 | Definitive BP7004 Main / Stereo Speaker
Mackie SRM 450, the main speaker has stopped working but the tweeter is OK, there is nothing coming from the speaker at all, no hiss, or clicks.
It could be 2 things:
*Blown Speaker or,
*Fried power amp output stage of woofer, since this speaker operates as a bi-amplified system it has separate amps for woofer/tweeter...
Aug 17, 2011 | Mackie SRM-450 System
Tweeter not working
hi,
Remove the tweeter and check the same with one AAA cell. Connect the two leads between the leads of the tweeter. if ther is no crakking noice from the tweeter the its coil is burned. you have to replace the tweeter.
ok
Feb 07, 2011 | Technics SB-T200 Main / Stereo Speaker
Only bass driver working on the pair. tweeter and mid range cones not working.
hi,
check the tweeter and mid range. its coil may become faulty.
for checking the speakers carefully remove the speakers one by one, remove its connections.
and check the speakers with a AAA cell. is it producing cracking sound. if not the speakers coils are burned.
ok
Feb 01, 2011 | Mission 782 Main / Stereo Speaker
Tweeter not working. Replaced it, but still doesn't work.
When you replaced the tweeter you should also check if there is any damage to the crross over network. It is possible that the capacitor , inductive circuit could have opened up. Remove and check. Check seperately with a good multimeter or use a 1.5 volt AA cell for testing the speakers. You can connect the speaker cabinet line to the battery and ccheck for voltage at the tweeter branch. Othere check the nettwrok and resolder or reconnect or replace. Hope this helps. Good day
Jul 20, 2010 | JBL SP5 Main / Stereo Speaker
Quite new speakers 9.1 but the sound is very dull - sounds like tweeters are not working can these be repaired
You didn't answer if they ever worked right.
One doesn't usually judge tweeter function visually. They don't actually move much.
Take a cylindrical tube (like from a paper towel) and place it over the tweeter to isolate it from the room sound and the woofer, then place your ear at the other end. Anything? Nothing?
What sort of signal are you feeding them? Let's look (or listen) to the source and how its audio gets to the speakers. Define the electronics, pathing and setup.
Maybe some history. Have you ever tried to blow them up in your enthusiasm for the new rig? If the tweeters are dead, that may have happened. Microphone use and feedback = dead tweeters.
Feb 20, 2010 | Wharfedale Diamond 7.1 Main / Stereo...
Tweeters poked to death
I know this sounds silly, but I had the same problem. Your speakers have a little plastic bulb that has been pushed in, right?
If so, simply put your mouth up to the tweeter, seal with your lips and **** gently (seriously). The tweeter dome should pop back out and in to shape.
It worked for me.
Good luck.
Aug 03, 2008 | Celestion AVF302 Main / Stereo Speaker
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
