Question about Breville Die Cast 800ESXL Espresso Machine
Where can I find the model number? My Breville espresson machine is named Cafe Venzia. Problem one water leaks from behind and under machine when I push the power button to heat up water. Problem 2 is now the steam does not build up and come out of the frother. Problem 3 is that is does not heat up properly. Is there a place is Toronto, that I might bring in for repair?
  • 17,970 Answers
I'm assuming that you are talkin about Caf? Venezia Espresso Machine BES250...
Try to find in THIS LINK the manuals/BES250XL (pdf) it possible that you need make any adjust in there!
I've had two of these units now. The first one stopped heating water after 3 months. I don't mean it didn't get hot enough...I mean it didn't even get above room temperature. Breville USA support promptly sent me a prepaid mailer to send the unit back to them and equally as promptly sent me a new one. Now after having that one for three months it will not power on...at all. Again, Breville USA has offered to send me a new one, which I'm waiting on. This will be three of the same unit.
Hope this helps.
Posted on Nov 15, 2010
I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
May 20, 2010 | Breville ESP8XL Espresso Machine
How do I get my breville cafe roma espresso machine to pump water out of the water tank and through the machine? It won't create steam or brew coffee and the water level in the tank won't deplete when the...
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
Dec 27, 2009 | Breville ESP8XL Espresso Machine
Breville Cafe Roma esp8xl
push down on the water reservoir. ours took a while to prime.
Aug 15, 2009 | Breville ESP8XL Espresso Machine
Water leaking out of the tank
i think you have to replace the gasket where the water tank fits, it´s very tight there, you have to take off the bottom from the machine then you will see two screw, loosen this.
Now can you put down your hand in the hole and take of the plastic above the gasket.
Hope this will help you.
/Mirran
Aug 15, 2008 | Breville ESP8XL Espresso Machine
Water on cafe
May be too much coffee in the coffee container leaves water above the filter. Just a guess John
Aug 03, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
Jul 21, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
85 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
