Washing machine drum bangs loudly as it spins to dry clothes
  • 10,319 Answers
The drum is turned by a belt that surrounds 80 percent of it. The other 20 percent of this belt goes through a belt tensioner. This tensioner has a idler pulley with a bearing in the middle of it. The bearing has seized up causing the pulley not to turn making the pulley to get a flat spot. That flat spot causes the banging noise. Sears does sell the pulley & the belt in a kit to replace your faulty parts. The top and front panels has to be removed to gain access to the drum. The drum will pull straight out for servicing these parts
Posted on Nov 14, 2010
  • frank thomas wilson
    frank thomas wilson Nov 15, 2010
    I am very sorry for I was thinking of a clothes dryer instead of a washer
    Please disregard my answer
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
Washing machine makes a loud banging noise during cycle and when I check it the machine has changed position (unit is turned slightly sideways) How to correct
Hi
Does this happen every time???
If YES... then the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
If NO.. only sometimes...
You are overloading the machine with heavy clothes... distribute your wash clothes by weight...
Regards
Berry
Feb 04, 2010 | Washing Machines
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Tub is banging loudly on spin cycle . machine is leveled
please check the shock obsorbers and replace them if they are not holding the drum.
Dec 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine was making a loud banging/tapping niose when the drum was spinning. It doesn't sound too good when turned manually. Is it the bearings and are they easy to fix?
banging may happen due to low load also, as cloths form a ball shape at one place.
otherwise it might be bearing or bearing housing. bearings are very difficult to replace as whole drum need to open. if bearing housing got loose in drum then drum needs replacement, also very costly.
Nov 18, 2009 | Ariston Technologies Washing Machines
Loud banging when spinning
but a small load in . if happen then it sounds as if the bearings have gone at the back of the drum.
May 12, 2009 | Washing Machines
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
