Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool Thin Twin washer won't drain... lid switch is fine
  • 1028 Answers
SOURCE: Whirlpool Thin Twin Lid Switch and Return Pump access
where the washer and dryer attach just above washer lid there should be screws to rmove cover between units yours may have clips instead of screws that need to be removed to remove lid and top on rear edge of top there is a plug that hooks lid switch just watch when reinstalling top to be sure it reconnects..sorry for mix up those units had 2 different layouts over the years and without an image hard to tell which one you had
Posted on Jun 13, 2008
  • 10 Answers
SOURCE: lid switch
to replace lid switch unplug unit remove two screws for acess panel(runs at angle between washer and dryer)after removing acess panel you should see two 5/16 head screws holding the washer top down (at rear of top) take out these screws top should slide forward .unscrew the two phillps head screws holding switch to the top replace switch then work backwards to complete
Posted on Dec 27, 2008
  • 125 Answers
SOURCE: Whirlpool Thin Twin Washer - does not drain water.
MAKE SURE THE CONNECTION ON THE TOP PANEL FOR THE LID SWITCH IS GOOD. ON OCCASION WHEN THE TOP PANEL IS SLID BACK IT CAN BEND THE BRACKET THAT HOLDS THE FEMALE END ON THE CONNECTION. HOPE THIS HELPS
Posted on Feb 11, 2010
hh0405
  • 77 Answers
SOURCE: Whirlpool thin twin stacked,won't agitate or spin
whirlpool washers have a drive coupling in between the motor and the transmission to replace this remove the top and disconnect the lid switch set it aside remove the front panel then remove the 2 clips that hold the pump on then push it out of the way then remove the 2 screws that hold the motor clamps on and then remove the upper and lower motor clamps remove the motor then replace the three piece "motor coupling" one piece goes on the motor the other three pronged plastic piece goes on the transmission and the rubber isolator goes between them and now just put every thing back together
Posted on Apr 01, 2010
tbirdfan1
  • 3051 Answers
SOURCE: I have a whirlpool heavy
Hi mary
Sorry we got disconnecteddo you have a e-mail address i can send the pict to
Posted on Sep 27, 2010
Washer is not working, was drying clothes and when I check them I noticed washer was full of water, drained water and washer not working.
sounds like lid switch problemes, just bypass it to test, if you ear the motor running and it doesnt turn then it should be the coupling between the motor and transmission thats broken, good luck, Alain
Jul 12, 2015 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
I need to replace lid switch on Whirlpool Thin Twin washer/dryer unit. How do I get the switch out and the new one in
The 3 screws across the front of the slanted panel need to be removed, then the panel. At the left and right rear of the main washer top are 2 5/16" screws, these need to be removed, there is a loose fitting steel clip through a slot on the main top these are holding down, when the 5/16" screws are removed slide the entire top forward and it will release from the front fixed clips. Unplug the lid switch unit and the main top can be set aside to replace the switch. Pleazer Appliance...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
I have a electric whirlpool thin twin. It fills with water and agitates...then nothing. No drain, or spin.
check the lid switch,open the lid and on the right side you'll see a hole in the top panel,stick a screw driver in it,push down,you should hear a click,or close the lid and open it a couple of inches and close it,do this a few times,no clicking sound bad lid switch.
Sep 12, 2011 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin Washer - does not drain water. I have replaced lid switch and water pump.
Feb 11, 2010 | Whirlpool Washing Machines
Whirlpool thin twin filled with water then stopped!
Not sure about the dryer but there are a couple things that could cause the no draining issue.
You could have a leak or block in your pressure hose. Basically there is a thin, clear tube inside the cabin that attaches to the tub on the lower right side. If this has a leak or is clogged then the washer has problems filling and draining.
The other possible problem is a broken lid switch. This is an easy fix. Basically, the mechanical mechanism that goes down when you close the lid does not work properly so when it comes time to drain, the washer actually thinks the lid is open.
For both of these you would need to open cabin. I posted instructions for that here:
http://www.fixya.com/support/t1885690-whirpool_twin_washer_dryer_lte5243dq3
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Jul 21, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
600 people viewed this question
Dan Webster
Dan Webster
Sal De
