Question about HP Pavilion dv2715nr Notebook
LOADKEY FAILED WITH ERROR 3 (STHIVE#O) - HP Pavilion dv2715nr Notebook
4 Suggested Answers
  • 2246 Answers
SOURCE: At startup, my HP laptop (running Vista) says
reinstall your pc, not as repair modde but with new instalation mode, but your data at drive C: will formated, back up it first before you reinstall
Posted on Jan 17, 2011
rajdeepdutta
  • 2517 Answers
Hi there you need to format the operating system and install a fresh copy on the PC for solving the problem.
  • 59 Answers
SOURCE: LoadKey failed with error 999
http://www.technibble.com/forums/showthread.php?t=8241
I found this in another fourm it may help I dont know never tried it I always clone my HD once a week so I always have a back up if anything like this goes wrong
Posted on May 15, 2011
Spindle test Failed (Error code: WCD44-RVH)
Spindle usually refers to the spinning axis of the carbon disks or the platters. The disks are likely not spinning and a drive replacement is required.
Jun 25, 2014 | Dell Inspiron 530 Desktop Computer
LoadKey failed with error 999 (STHIVE#0)
May 15, 2011 | Computers & Internet
At startup, my HP laptop (running Vista) says "Loadkey failed with error 999 (STHIVE #0). It prompts me to run startup repair, but that just brings me back to the same place. HELP!
Jan 17, 2011 | HP Pavilion dv2715nr Notebook
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My HP pavillion comes up with a blue scrren and reads loadkey failed with error 1392 (STHIVE#0) its run on vista and the model is dv6500
Could be a driver problem.
Uninstall newly installed drivers or programs which might not compatible with Vista.
Or check for malware problems. Scan with Trojan Remover or other antivirus or spyware programs in safe mode to rule out malwares. If you have Avast Antivirus, schedule a boot time scanning. G'luck.
Dec 12, 2009 | Computers & Internet
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Wont start up
- Try to run the System Restore.
Mar 14, 2009 | HP Pavilion dv2715nr Notebook
Hp Pavillion dv2500 loads windows vista, but before the log in screen comes up, i get a popup saying "LoadKey failed with error 1392 (STHIVE#0)" No matter what I do from there, I get just a...
the existing installation has become corrupt. Do a fresh install. You may need to wipe the disk to ensure a problem free new installation
Jul 18, 2008 | Computers & Internet
HP Pavilion dv2715nr Notebook Logo
1,184 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
