SOURCE: B60 special edition clear water surge last couple ounces
Have you tried Descaling? In the manual, it recommends Descaling every 2-3 months, even though you mentioned that you've had yours only 1 month. Worth a try, anyway.
I know they carry a water filter thru Keurig.com for less than $18 that you install right on the water pump in the water reservoir if you live in an area where the mineral deposits are heavy. It lasts 2 months and you can buy 6 replacement cartridges for $25. I just put one in mine today and it took less than 6 minutes to install (5 of those minutes were spent just soaking it in clean water).
If that doesn't help, you can call their Support Team @ #1-866-901-2739 between 7AM-12 Midnight EST. Make sure you have the serial # of your machine before calling. It's located either behind the drip tray (just pull it out) or on the bottom of the unit.
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
SOURCE: When I turn on my Keurig Brewer B60 It says not
Normal
0
0
537
11.1287
0
0
0
Try the following steps to reset the processor:
1.
Simultaneously press and release “small mug” and “medium mug”. Immediately
afterward press “menu” 3 times. You should see a time 6:09 (or similar) on your
screen.
2.
Press “menu” once. Your LCD screen should say Brew 0:00.
3. Press
and hold “medium mug”. While holding “medium mug” press and release “menu”.
Immediately after releasing “menu” (while still holding “medium mug”) press
“small mug”. Release “small mug” and “medium mug” at the same time. This entire
thing needs to be done very quickly.
4.
Unplug the machine (do not turn it off). Wait for 3 minutes or so. Plug it back
in, turn it on and follow the instructions for priming.
SOURCE: B60 won't heat
check and make sure the resevoir is full and that the float switch in the resevoir is not stuck.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: My Keurig B60 will not brew. The "ready to brew"
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
