Question about Ovens
My Candy TC21 oven makes a vibrating noise when on, why is that?
    President:
  • 1,140 Answers
There are only 2 moving parts in your oven when it is running - the fan and the fan motor. If a bearing is worn or the fan blade is damaged, this can cause vibration. However, the actual noise could be could be coming from some other part of the oven which is insecurely fixed, e.g a panel, internal shelf, the oven/grill element - pretty much anything!
Basically, the fan/motor causes the vibration and a loose part causes the noise.
Hope this helps.
Regards,
BElectric
Posted on Nov 14, 2010
Candy fl 134 x uk , single oven ..... oven works fine ... clock/ timer is dead and keeps making clicking noise , when not in use i power it off ... do i just need to replace the clock ???? Thanks roy
[n 75 years I have never heard of anyone powering off an oven when not in use . those little clocks do not use enough electric to worry about waste
Feb 25, 2017 | Candy Ovens
The clock light is on but not the oven light and the oven doesn't work
what is the make of this stove/oven there is none listed as candy
Jan 31, 2015 | Candy F248P Electric Single Oven
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
Electric oven makes an awful vibrating noise when hot
yes it can,i have used double sided sticky tape tp put between the blower houseing and top
May 26, 2010 | Ovens
CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Feb 22, 2010 | Candy F248P Electric Single Oven
The oven makes a loud rattling sound when it reaches a certain heat (tends to be about 200 degrees) and then rattles intermittently until turned off. If you slam the door it does sometimes shut for a...
From what you describe is happening, I would say that it is the fan that is causing the noise, not neccesserily the oven fan, because there is an external cooling fan as well, and these are the only moving parts that could cause a noise.
Hope this helps.
Feb 02, 2010 | Candy FP855 Electric Single Oven
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration on...
Update: after using the oven with the grill instead of the fan, the problem sorted itself. With the heating and cooling, obviously some panel had not settled correctly and was causing the vibration. It hasn't happened again so far.
May 19, 2009 | Neff Ovens
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
Ovens Logo
614 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
