Question about Pride Jazzy 1103 Ultra Standard Power Chair
Light rolling from green to red - Pride Jazzy 1103 Ultra Standard Power Chair
  • 692 Answers
Stephen I think you are in sleep or lock out mode. Try turning the power on and pressing the horn button twice see if it stops scrolling if it doesn't turn the power off then turn it on and immediately push the joystick forward until you hear a beep then immediately opush it to the rear until you hear another beep then release it to the center. If it is in lockout you should see it return to normal lights Hope this helps
Posted on Nov 14, 2010
Red and green light turn after first run
Its common problem in T Series Plotters:
Cause of malfunction: These plotters having separate sheet path as well as roll path for print media. After initializing plotter its verify the available media(sheet or roll). If sheet path is occupied by the media it wont allow the roll media, means first priority is for sheet.If sheet path paper sensor dusty or malfunction, printer will say "remove paper from sheet path" even no paper in sheet path..
How to shoot this problem:
You need to clean sheet path sensor located at sheet loading area.(black 'U' shaped part) Applying the pressured air at sensor is the best method to clean.. If problem remain you need to remove the sensor & clean or replace it.
Follow the snaps:
Need to open roll feed right side portion
dadb8b23-32b2-4d8a-952b-038117715d5b.jpg f7392b92-295a-4144-8387-b83355c6889e.jpg 6f066468-8698-4d24-94d4-af1703c40407.jpg 6ed46665-db38-4ccc-8522-c52ae9c50dbf.jpg 37e6b4f2-cc2e-438b-849e-9911bd553c7e.jpg
Clean the IR sensor...
Fix it back..
Note: Technical knowledge required to understand the remedy..
Jan 26, 2014 | HEWLETT-PACKARD CP1025 Laser Printer
The green light on my Kirby Ultimate G is not on but brush is spinning suction is pick stuff up. Is there a light bulb or a bigger problem?
You are referring to the green led light on the front of the machine that tells you the brush is rotating? this is operated by a small magnet on the brush roll, when rotating it generates a small current to bring the light on. Remove the brush roll and check for damage behind the green led inside the case, also check for the magnet on the brush roll, ensure it is not missing and the brush roll is in the correct way round, magnet needs to be at green led end (ie to the left)
Magnet is fitted flush within the brush roll close one end and is around 6mm 1/4" diameter.
Green light not working will not affect the machine in any way.
Sep 26, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Green light
Aug 29, 2013 | Kirby Generation 3 Bagged Upright Vacuum
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Mar 13, 2011 | Epson Office Equipment & Supplies
Green and red light on doesn't print
Maintenance request error is not cleared until the waste ink pad is replaced with a new one, and the waste ink counter in EEPROM is reset by the service operation.
"try in this procedure
1. hold and press ink and roll button then press power on.
2. Red Led 10 times blinking
3. release roll button.
4. press ink button until all light blink at a time
Dec 31, 2009 | Epson Stylus Photo 1290 InkJet Printer
Kirby g4 vaccum
please clarify what you mean?
Do you mean motor bearings or brush roll bearings?
brush roll bearings can be adjusted to lower the brush closer to the carpet when worn.
to do this remove the front brush assembly, there is usually a sticker below the belt hole showing RED = POSITION 1 HIGHEST (ie a new brush roll)
GREEN = POSITION 2 MIDDLE (brush part worn)
BLACK = POSITION 3 LOWEST (brush fully worn)
At each side of this there are 2 clips unlock these and remove the bottom cover.
Release the belt tension by rotating the belt release at the front.
Before removing the brush roll, at each end of the brush roll there is a grey plastic bearing carrier (Square at the ends) MARK this with a pen or marker just so you know the original position, also look closely for the coloured markings as indicated above or numbering 1,2 or 3.
If RED or "1" is showing you need to remove the brush roll by pulling it out and rotate the endcaps to Green or "2" and re-insert the brush roll, If Green or "2" is showing then rotate the endcaps to Black or "3" and re-insert.
If Black or "3" is showing then the brush roll is worn and cannot be adjusted any more, fit a new brush roll and insert with RED or "1" showing.
To re-attach the belt, move the belt to the middle of the roll and rotate the belt knob at the front ensuring the belt engages with the hook on the inside.
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
Red light stays on
Most likely the hose or the inlet down by the brush roll has a clog in it. The red light indicates a full bag, but if there is a clog, then it thinks it has a full bag.
Dec 07, 2007 | Lindhaus Activa 30-38 Bagged Upright...
Zebra LP 2824
the error you are getting is a label size error. a label variance of as little as 1/203th of an inch can cause this.
you need to recalibrate the printer to the media, hold feed when powering up the printer letting go once the light flashes 4 times. this will force the printer to autodetect the label size.
if you are specifying the label size in you software or driver settings, measure and double check the label size
Dec 04, 2007 | Zebra TLP 2824 Printer
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
77 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
