Question about Canon PIXMA MP150 All-In-One InkJet Printer
Hellow. The lights indicate trouble with the ink. I have replaced the ink and want to do a cleaning, but it only shows E and 5. I can not get the leter H or F for maintenance, and the machine does not print. Thank you.
    Problem Solver:
  • 11 Answers
Let me give you instructions to get to service mode.
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
* When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
* When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
* When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
* Turn off the printer.( it must be turn off) then turn it on again.
Posted on Nov 14, 2010
U150 error on canon mx885
Solution 1:
  • Open the paper output tray.
  • Turn on the printer and open the scanning unit. The printer cartridge carriage will move to the center. Open the inner cover securing the cartridge in place by pulling it downward.
  • Press the tab on the problematic ink cartridge and lift it to remove it from the printer. You will be able to tell which ink cartridge is causing the problem because its indicator light will be off or flashing.
  • Open the replacement ink cartridge and pull the orange tape in the direction of the arrow to remove the protective film. Tear the orange tape off along the dotted line.
  • Place the ink cartridges into the printer and press where indicated on the cartridge until it clicks into place. Ensure that all ink cartridges have a red indicator light showing that they are properly installed.
  • Close the inner cover on the cartridge carriage and the scanning unit. The printer will automatically start a print head cleaning cycle. When the cleaning cycle is complete, the printer is ready to use.
Solution 2:
  • Put the little green circuit board from the old ink cartridge of the same color in the new cartridge.
Apr 17, 2012 | Canon Office Equipment & Supplies
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My pixma mp 145 is not working. it shows error 5.please give me its solution
Error 5 means
The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
try to change your catridge if it is old one.
Hope this helps
Thank you
Oct 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Red light flashing above ink symbol but plenty of ink
hello! the ink indicator is showing because the catrigde sensors could be coated by some dirt or ink . try cleaning the catridges slot with soft material .then put it on
Jul 10, 2009 | HP DeskJet 940c InkJet Printer
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
My printer is not working since we had a power outage.
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The flashing orange and green alternately light indicates that the error the printer is experiencing requires it to be sent into an authorized canon service facility.
Replacing the waste ink absorbtion pads is something the service facility can take care of for you. Once they are replaced, it'll be functional again.
May 28, 2009 | Canon Office Equipment & Supplies
Overiding Empty Cartridge error for Dell A10 962
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Nov 15, 2008 | Dell 962 Photo All-In-One InkJet Printer
Canon MP830 message re: waste tank full. How do I get to it to empty it or replace it.
The waste ink tank refers to may be a small well, surrounded by a
rubber ring, that sits under the cartridge when it is parked.
Place a cotton tip swab ("Q-Tip") over the hole to wick out the ink inside.
Oct 07, 2008 | Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
