Question about GE Spacemaker JVM1640SJ Microwave Oven
Keypad inoperable Suddenly and automatically my GE Sapcemaker started running last night. I can not stop it. The keypad is not operable. As long as the door is shut, it keeps running. However, anything I put inside the oven can NOT be heated. So, it sounds like it is working, but actually NOT. I have to plug off the oven or open the door to stop the oven. George
  • GE Master
  • 9,098 Answers
Does the display say F3? You probably have a shorted keypad.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
(Remove the grille from across the top, remove the top screw in the control panel frame, then lift up & out).
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off.
You have to make sure all the old adhesive is off or the new keypad will not stick.
I use paint thinner or mineral spirits, then follow up with isopropyl alcohol to be sure the panel face is squeaky clean and dry.
Then peel the backing paper from the new keypad and carefully press the new keypad in place.
You need to be precise - you cannot apply it, peel it off, then reapply it.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jun 23, 2008
Amana microwave amc2206bas troubleshoot
This indicates a problem in the keypad control board, or trouble with one or too door switches. This is a situation where I recommend a technician.
Jun 09, 2012 | GE Spacemaker JVM1540 Microwave Oven
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
The microwave is beeping at intervals and is flashing an F-3 Last night the vent was running full force and the beeping was going on too - I unplugged it but it didn't fix the problem
The error code of F3 on the GE microwave oven indicates a shorted keypanel/keypad.
Most likely the keypad will have to be replaced to fix your problem.
Mar 10, 2011 | GE JVM3670 Microwave Oven
I have a GE Sapcemaker XL1800. Last night when I went to push express cook for one minute all I got was a small roar and after the one minute was done, my sandwich was not heated. We tried it several more...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave is unresponsive
I suspect the controller is a low-level microprocessor that may even have its own programmable chuck of memory on board to adapt to different models. Either the clock (for synchronizing the processor) is no longer running or the processor itself has failed.
I doubt if this board is considered repairable so figure on replacing it. It probably cost all of $5 to produce but likely in the upper two digits to buy.
Unfortunately, GE quality and that of their sources (they don't build much of it) has dropped drastically in the last decade.
Mar 28, 2010 | GE JVM1540DM Microwave Oven
Runs whenever door is shut, displays "8 lo code", can't cancel
This is usually a shorted keypad or a problem on the control board.
We regularly repair these for customer nationwide for only $39.95, plus parts cost if a keypad is needed.
Please feel free to contact me directly if you need more help.
prototech@usa.net
Jun 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Night lights do not work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 02, 2008 | GE JVM1660 Microwave Oven
Keeps beeping and shows F3 but keypad not working
Ya what the ????
Not shure what to tell you, first I would see if leaving unplug for a day would solve your problem, to me sound like main board is defective, also try by opening the door a closing it a couple of time, just in cass a switch is jam open.
Regards
bob
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
228 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
