Question about Refrigerators
I have sylvania se80106-2 bar fridge. compressor runs and get hot but no cooling
  • 4 more comments
  • zafar11 Nov 14, 2010
    it is a compact design and i can not see any evaporator or any thing else but only the compressor so hoe i can check for any leak. it does not have even a freezer or fan. thanks
    I already tried that but it did not help Thanks
  • zafar11 Nov 15, 2010
    this will be last thing I will try .
    themostat is working fine as i can turn off the refrigrator with it
  • zafar11 Nov 17, 2010
    how do I find out if it is low on134a. It was running fine before we move it another floor. Thanks
  • zafar11 Nov 19, 2010
    It wad wqorking fine until we move it to another floor so how could it be low on 134 unless there is a big leak and I dont know how to check the leak as all I can see is the compresor outside.
  • 2,973 Answers
If the compressor is running and there is no cooling then the gas (feron) may have leaked out. The only way out is to get the gas refilled.
Posted on Nov 17, 2010
  • 10,319 Answers
Most likely low on freon and oil for the compressor
Posted on Nov 16, 2010
You will need to replace the thermostat to get your bar fridge to start cooling again. Use a multimeter and check the thermostat for continuity, replace if there is no power going to it.
Posted on Nov 15, 2010
  • Anonymous Nov 16, 2010
    Also check to see if it is low on refridgerant. If it has a condensor coil, that could be dirty/clogged causing excessive heat
  • Refrigerators Master
  • 43,501 Answers
Try running your refridgerator out in the opne with nothing around it...
The condenser coils are inside the side and top panels and if you have it in too tight of a spot so that there is no air flow around it, the cooling unit will not work right....
Give the unit some air and it will probably start to cool.....it will take a few hours even then for you to really notice it getting cold... this is not a high power unit...
heatman101
Posted on Nov 14, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 15, 2010
    Okay if that does not work then you probably have a problem in the refrigerant system...if it is running and the compressor is hot then most likely the problem is dirt in the system that has stopped the flow of the refrigerant...
    To fix this all the refrigerant will need to be removed and the system vacuumed and cleaned... this may work but may not work...
    The only way to tell if that is the case for sure is to put gauges on it and see what the pressures are...this also will take special equipment to fix...
    The repairs also could easily be costing more then a new fridge would cost... check it out before trying to repair...
    heatman101
  • 22,246 Answers
It needs regassing and checking for a gas leak
A amana French door fridge no fan water or.icemaker lights come on but no fan turning on or cold
Many Amana model fridges have the freezer fan wired through the bi-metal thermostat that is clipped to the evaporator. Either your compressor has a bad start device and that is why it is not cooling, or the compressor IS running and the unit has lost its refrigerant charge. Running compressor with no cooling = buy a new fridge.
Compressor hot, but not running = start relay replacement to get the compressor going. Start Device 8201786
May 13, 2016 | Amana Refrigerators
U-Line 75FF Bar refrigerator stopped cooling
it could be a problem start/run capacitor for the compressor or compressor failure
get a fridge technician in to test and get a quote
Most small fridges are cheaper to replace than repair
Jan 09, 2016 | U-Line Refrigerators
Bar fridge not cooling
Sounds like you might be low on refrigerant (gas). Unless it is 134a, which you can buy in automotive stores, you are going to need a license to buy refrigerant. The simple way to see if you might need gas is by feeling the larger line going into the compressor (probably insulated). It should be cold if your system is working and charged. If you feel the line leaving your condenser, it should be fairly warm. Be careful as the line leaving the compressor can be very hot and burn you and you may have exposed electrical. If the lines do not feel cold and warm as they should you may be low on gas or you may just have a problem with your compressor or another part of the system. If you're not getting the warm-cold differential, it's likely worth just buying a new unit.
Nov 12, 2013 | Amana ARB1905C Bottom Freezer Refrigerator
I have kelvinator fridge it doesn't cool in both compartment we replaced the compressor il coold down for only 3dayes then returned back to hot state
is the condenser fan running back there?also did you clean out the condenser coil?usually when the middle strip gets hot the coil is filled with dust or the fan where the compressor is isn't running.the condenser fan keeps the compressor cool and all the heat from the machine escapes out through the condenser coil.check this,also the start device could be bad on the compressor,send model number next time you write so whoever helps you can look up your machine.hope this info helps you out.
Sep 15, 2012 | Kelvinator Refrigerators
Samsung RSA1NTPE not cooling in either the fridge or freezer. Seems like the compressor is not running although it is hot too the touch.
the compressor is seized and wont pump and the motor keeps trying
to work and thats why its hot,sorry to tell you but you need a new
compressor
Aug 21, 2012 | Samsung Refrigerators
My fridge compartment and freezer compartment is warm. i dont know alot about fridges, so please dont be too technical with me. and its a very old model, 106.769830 E92812566
If both compartments are warm, this means that the compressor is either not running or is running and not circulating the refrigerant. We need to know if the compressor is running. Its the black can looking thing behind the refrigerator at the bottom with copper tubes going to it. If it feels cool to the touch it is not running. If it is warm or hot, it is running and not pumping. If its not running it may be a problem with the thermostat, the defrost timer or the compressor itself. If it is running and hot but the fridge isn't cooling, it may have a leak or a bad compressor or relay.
Feb 20, 2010 | Refrigerators
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
Refrigerators Logo
504 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
