Question about Microwave Ovens
I have a Thermador Range oven and one of the front doors will not close all the way. The model number off the sticker on the unit is PRD484EEHU/01 serial 39711008587. When the unit is on convection you can clearly feel the air coming out of the oven, and food cooks unevenly. It doesn't feel like the springs in the hinges are broke, but I'm thinking they must need replaced. Does anyone know how to tighten them up, or how they are replaced? Or, where do I purchase them online? I've pulled the front cover off myself, hoping I can fix this myself so I won't have to pay someone a fortune! Please let me know. Thank you in advance!
  • 1 more comment
  • ebroughton08 Nov 14, 2010
    Is there a way to just tighten the spring instead of replacing the entire hinge?
    Found the part, very quick help, thank you!
  • ebroughton08 Nov 17, 2010
    I got the part for my oven, and it's not even close to the same spring. what gives? any thoughts?
  • 1,711 Answers
We have here below the link with yours model parts including door
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5110041&diagram_id=191132#d191132
As you may notice your thermador is produced from BOSCH.
Also we have here some video links which can help you how to replace hinges and disassemble the door.
http://www.youtube.com/watch?v=kESnnYR4VhM
http://www.youtube.com/watch?v=hSzc4Uqbbr8&feature=channel
Posted on Nov 14, 2010
  • espressonist
    espressonist Nov 14, 2010
    No the tightness is only due to the strength of the spring which doe to heat and long time use they shlitly loosen up and this can not be fixed, need to replace the hinges.
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
GE model number jvm1790sk 01 over range microwave convection oven turns on when door is closed but i think it is the convection oven that is on cause the turn table does not turn and the light does not...
That's probably a shorted relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 16, 2011 | GE JVM1790 1000 Watts Convection /...
I need to replace the waveguide in my Thermador MBBS / 01 microwave.
Waveguide "cover"I presume? The waveguide is part of the chassis and cannot be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 26, 2011 | Thermador MBBS Microwave Oven
Same issue with my Thermador Microwave!
You may want to look into the possibility of a "panasonic" (specifically a "genius" model) microwave unit that should fit there nicely. most of those Thermador 3 component units had the m/w built by panasonic. (though you'll not get them to tell you that)
I'd like to add, I find it unlikely your's is "burned beyond repair". what is the problem, if you'd care to elaborate.
Perhaps your m/w can be saved, or revived.
Sep 25, 2009 | Thermador MBBS Microwave Oven
TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Sep 14, 2009 | Thermador MBBS Microwave Oven
Inside front of oven door is a water build-up
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 09, 2008 | Thermador MBBS Microwave Oven
Door Latch mechanism is broken
Normally on over the range models, you would unplug the oven from the wall, remove the 2 or 3 screws holding the top grille in place, remove the screw at the top of the control panel frame, then CAREFULLY lift up and out to remove it.
If it is a counter top model, you need to remove the outer cover before remoing the control panel frame.
If you can give us the full model number from the sticker, we might be able to give you more specific help.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 12, 2007 | Thermador MBBS Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
